20 Most Recent
Sharp XR-10S DLP Projector Questions & Answers
The image projected is squished
It sounds like your input signal is in 4:3 and the projector is in 16:9.
You need to adjust the "Resize" mode.
On your remote, press the "Resize" button (bottom-right of the remote, looks like a screen with two arrows pointing left and right [< >]) until it is in "Normal" mode. If that does not work, try setting it to "Border".
Hi Guys,
look at your lamp carefully to see if you see bubbles in the mirror or anything like that. if so then your power supply/ballast is bad.
Sharp projector lamp will not come on
It is mother board problem.Reverse side of the board 5 pin ic not giving 12 volt.pin no. 1 input 12volt and pin no.3 12 volt out.it might be damage
