20 Most Recent
iRiver E100 Digital Media Player Questions & Answers
Can not transfer or down load music to my new Ipod
Download a free copy of itunes.after install plug ipod in and set-up.a new ipod does not have files required for loading.Your download is here https://swdlp.apple.com/cgi-bin/WebObjects/SoftwareDownloadApp.woa/2192/wo/axb8uETTTfApwgQBbo5pX0/2.5.If you require further assistance contact me here at FixYa.please do not forget to vote.RICHARDM69
How do you replace the battery in an iriver e100
I pulled mine apart to find out what to do because without the battery it was preety much useless. I got the top off using my fingernail around the sides. then there are 4 scresw to remove with a jewlers screwdriver. Two are easily sen and the other two are under screed which is held down with a strip of fine glue. the screen comes u without problems showing you the two remaining screes. then the whole circuit board lifts out. the battery is also glued into place and that eaily liftsout with gentle pressure. the trick is the battery wires, red and black, which are soldered into place. so you need a very low heat fine point soldereing iron to do that. Assembly is the reverse with the top piece being pushed into place around the edges. It goes back together very well. I did it twice. Hope this helps.
Iriver e100 2gb problem with the firmware upgrade
Yes!
Go to Iriver.com international site.
down load file :
I can't upgrade New Firmware of E100 (For firmware 1.05)
Should take less 30 sec.
And Use with Iriver plus and do the another update.
Shuold take less 30 sed for version 1.22.
Works after spend long hours.
Iriver is good, there is sleep timer, good video quality plus samll speaker to.
Have a fun!
