20 Most Recent
GPX 2.1 Speaker Bar with ipod Dock Docking Station, Speaker System Questions & Answers
My iLIVE mod# IT188b will not turn on.... reset
This particular unit has issues with bad solder connections on the main audio board which come loose because the woofer speaker vibrates them loose. I've repaired unit myself with a soldering iron.
My ilive speaker bar IT188B will not play through
Make sure that your audio in on Ilive unit is going to your tv's audio out. Your tv may have a setup to able the audio out. Refer to your tv's owner's manual. I have to do this on my tv to my Ilve unit.
My gpx mw240s says error and i cannot play any music. What else should i try doing?
If your GPX MW240S MP3 player is displaying an error message and not playing any music, there are a few things you can try to fix the issue:
- Reset the player: Sometimes resetting the MP3 player can fix the error. To reset the GPX MW240S, press and hold the power button for 10 seconds, release the button, and then turn the player back on.
- Check the music files: Ensure that the music files you are trying to play are in a compatible format with the GPX MW240S. The player supports MP3 and WMA formats, and if your files are in a different format, they will not play. You can convert the files using a free online converter.
- Update the firmware: If the player's firmware is outdated, it may cause errors while playing music. You can update the firmware by downloading the latest version from the GPX website and following the instructions.
- Check the storage space: If the MP3 player's memory is full, it may cause errors. Delete some files from the player to free up space.
If none of these solutions work, there may be a hardware issue with the player, and it may need to be repaired or replaced.
2/26/2023 2:26:50 PM •
GPX Audio...
Answered
on Feb 26, 2023
On my gpx cd home music system HM38170T the cd door won't open. How do I fix it?
If the CD door on your GPX CD home music system HM38170T won't open, here are a few steps you can take to troubleshoot the issue:
- Check for obstructions: Make sure there is nothing blocking the CD door or the area around it. Sometimes small objects or debris can get stuck and prevent the door from opening. If you see any obstructions, carefully remove them.
- Power cycle the system: Turn off the system and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. Sometimes power cycling can help reset the system and fix any issues.
2/19/2023 10:00:38 PM •
GPX Audio...
Answered
on Feb 19, 2023
Downloading songs from itunes to the MP3 player
The GPX mp3 player is incompatible with iTunes (as are most non-iPod mp3 players). There are a few mp3 players out there that are iTunes compatible, but this is not the one.
-Tha Mp3 Doctor
11/18/2022 3:15:32 AM •
GPX Audio...
Answered
on Nov 18, 2022
Brand new GPX mp3 player will not pair or show up on usb drive
Instruct the computer to search for it. The computer should automatically find it and load drivers, but it should show in Windows Explorer as a volume in the left pane. Where are you looking?
It will only pair with a computer if the computer has Bluetooth and most don't. Pair with a smartphone.
How do I transfer my music to my device?
This device is capable of playing MP3 and WMA (4ithout DRM) files. To load files requires a computer with a USB connection and the minimum requirements of Windows XP .
- Connect the player to the USB cable provided in packaging, and then connect the other end to your computers USB port.
- Once connection has been made between the device and your computer, a "GPX" drive will appear in the computer directory.
- Double click on the GPX drive
- Drag and drop your MP3 files and folders into the Music or playlist folder
https://gpx.com/on-the-go/gpx-bluetooth-mp3-player-mwb308r.html
3/6/2022 8:42:20 PM •
GPX Audio...
Answered
on Mar 06, 2022
