20 Most Recent
Motorola Mobility Motopure H12 Bluetooth Headset Questions & Answers
How do I pair my Motorola H12 with my iphone
1)Turn on the bluetooth headset.
2) Turn on bluetooth on your phone. It starts looking for bluetooth devices in the vicinity. Your headset will be detected as "bluetooth headset" or "Motorola H12 Headset".
3)Once its located then select it and follow the onscreen instructions like choosing a passkey etc., to complete the pairing process.
11/26/2016 5:47:14 AM •
Motorola...
Answered
on Nov 26, 2016
I phone
the wesites are not much help for this one are they? I just figured this out a few minutes ago...I have the same headset.
1.) press your home page button at the bottom of the iphone
2.) touch the setting icon (gears)
3.) touch the general settings icon when it opens up
4.) touch the bluetooth tab (middle of screen)
5.) turn on your H12 and make sure the blue light is solid and place next to your iphone
6.) turn on the bluetooth...devices will come up...your H12 will be listed
7.) enable connection...badda bing! your done!
2/2/2012 4:08:18 AM •
Motorola...
Answered
on Feb 02, 2012
Even though my H12 is
unpair it from your device and pair it again or try restarting the device your connecting it too and unpair and pair it again. Hope this works!
9/10/2011 8:43:28 PM •
Motorola...
Answered
on Sep 10, 2011
My motorla bluetooth pairs with
Sometimes two diffrent brands will not communicate proper.
Try connect the headset to another phone is it now working?
If Yes --> then I'm sorry but it seems your cel and the headset are not compatible.
If No --> then the problem is most like a technical defect. Go back to your reseller for another headset or let your reseller demonstrate a correct functional headset.
Good Luck.
8/3/2011 11:23:38 PM •
Motorola...
Answered
on Aug 03, 2011
Motorolla h12 wont charge
Yo! that has to be a problem with the charging port of the phone. in which case you will have to replace it.see a electronic engineer to fix the problem.take good care.
7/20/2011 8:15:45 PM •
Motorola...
Answered
on Jul 20, 2011
I need the password code
You could try the bluetooth generic passwords (0000 and 1234), these usually work with most devices.
5/3/2011 5:08:40 PM •
Motorola...
Answered
on May 03, 2011
I am wanting to change
The factory set passcode is 0000 (zero's not O's). If you changed this then you will need to reset your bluetooth to go back to the 0000
4/20/2011 9:18:05 PM •
Motorola...
Answered
on Apr 20, 2011
My H12 has no sound
In that case it could be as simple as needing a new little speaker. The one in there is probably high-quality, but you should be able to replace it with any little speaker-- say from a pair of headphones. I successfully repaired the same problem in my Jabra bluetooth using this method.
It could also be a radio problem, however. Bluetooth headsets allow you to talk at the same time as the other person, so they use two frequencies at once. It could be that there is something wrong with the transmitter, but I'm afraid repairing that is beyond my abilities.
4/19/2011 9:33:00 PM •
Motorola...
Answered
on Apr 19, 2011
After about a year of reliable service, I am
An orange blinking light on a motorola headset often signifies that the headset (or possibly the charger) is damaged or defective. If it has been less than a year since your original purchase, you can find out if you can get the headset replaced under Motorola's one year limited warranty
here.
3/5/2011 4:03:22 AM •
Motorola...
Answered
on Mar 05, 2011
How do I pair this bluetooth device to a phone
First step is to turn the blue tooth power to on in your phone menu,then you must put your blue tooth device into discovery mode,Now most blue tooth manufactures use the power button for thiws feature,when turning your device on keep holding the power button sown for 6 to 10 seconds a solid light usually stays on,this means you are in discovery mode,then you can add new or search for device from your phone menu,once it finds it it will ask for a pin pairing code.Most manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999. enter one of these codes starting with the first one ,when it recognizes the pin it will pair and you are ready to use your blue tooth device,glad to be of assistance
2/26/2011 8:03:41 PM •
Motorola...
Answered
on Feb 26, 2011
