20 Most Recent
Motorola Mobility H680 - Headset - wireless - Bluetooth - black Questions & Answers
Why can't I charge my headset
James
Sorry you are having an issue. Have you tried another charger? If so and it still doesn't work. CONTACT US . If you have proof of purchase that it was purchased new less than year ago then we'll replace it.
Mark
Motorola Support
12/24/2014 6:53:22 AM •
Motorola...
Answered
on Dec 24, 2014
How do I pair my Motorla h680 to my blackberry
In order to pair your headset with your phone, when you turn it on for the first time, its indicator light should be steadily lit in blue, thus indicating it is in pairing mode. If it has been paired to another device before, make sure that that device's bluetooth radio is turned off. If the light is not steadily lit, turn your headset off, wait for some 10 seconds, and turn it on again. Anyway, whilst its light is steadily lit, make you phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (indicator light starts flashing in blue). You see, the pairing procedure between any two bluetooth enabled devices should be performed just once. All subsequent connections between them should be achieved just by bringing they within each other's range, with their bluetooth radios turned on. At most, a simple press on the headset's call button should do.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Please, let me know if I can help you any further.
Regards,
Carlos
6/28/2011 3:39:57 AM •
Motorola...
Answered
on Jun 28, 2011
I am trying to pair
Regards, Carlos
6/28/2011 3:38:17 AM •
Motorola...
Answered
on Jun 28, 2011
I want to use my
It is hardcoded to '0000' (four zeros). Well, w
hen you turn it on for the first time, its indicator light should be steadily lit in blue, thus indicating it is in pairing mode. If it has been paired to another device before, make sure that that device's bluetooth radio is turned off. If the light is not steadily lit, turn your headset off, wait for some 10 seconds, and turn it on again. Anyway, whilst its light is steadily lit, make you phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, it should enter the stand-by mode (indicator light starts flashing in blue). You see, the pairing procedure between any two bluetooth enabled devices should be performed just once. All subsequent connections between them should be achieved just by bringing they within each other's range, with their bluetooth radios turned on. At most, a simple press on the headset's call button should do.
Regards, Carlos
6/20/2011 12:37:50 AM •
Motorola...
Answered
on Jun 20, 2011
Dont no my passkey
Should be 4 zeroes, as in '0000'. No quotes. If it was changed, try holding the button down for 10 seconds and you should hear the unit beep when it has been reset to the default.
6/17/2011 9:30:23 PM •
Motorola...
Answered
on Jun 17, 2011
