20 Most Recent Motorola Mobility H710 Bluetooth Headset Questions & Answers
3answers
I have a710 blue tooth but don't know the pass
The normal passcode is 0000
1/9/2017 6:06:33 AM • Motorola... • Answered on Jan 09, 2017
My voice does not transmit through the earpiece
Sounds like you have a problem with your microphone. Please contact us. Mark Motorola Support CONTACT US
10/25/2015 3:26:41 PM • Motorola... • Answered on Oct 25, 2015
Why can't Bluetooth be turned on?
Hi Wahab Williams, Have you tried a different charger? Please try a reset, press and hold the power button for 10 seconds. Best regards Suny Motorola Support
9/17/2015 3:20:13 PM • Motorola... • Answered on Sep 17, 2015
How to delete from pairing and start over
Delois On touch screen phones long press the device and a popup to remove should appear. Mark Motorola Support
3/5/2015 10:44:30 PM • Motorola... • Answered on Mar 05, 2015
Shutting down and restarting
Joe If the battery is depleted it will turn off. It may be expended. Rechargeable batteries cannot be recharged forever. Mark Motorola Support
3/5/2015 10:34:02 PM • Motorola... • Answered on Mar 05, 2015
Will not hold a charge
Close mic boom and then try to charge. Mark Motorola Support
1/27/2015 1:47:15 PM • Motorola... • Answered on Jan 27, 2015
H710 I cant hear music on it?
H710 isn't A2DP compatible so you can't listen to music. mark Motorola Support
1/11/2015 8:44:20 PM • Motorola... • Answered on Jan 11, 2015
How long should i charge it
I would charge it overnight. Mark Motorola Support
8/28/2014 3:01:29 AM • Motorola... • Answered on Aug 28, 2014
How to use H710
It is a multi-function button and has multiple uses. Please check the manual here: https://motorola-global-en-uk.custhelp.com/ci/fattach/get/545008/1353538144/redirect/1/filename/H710_GB_EN_QSG.pdf Mark Motorola Support
8/28/2014 2:27:40 AM • Motorola... • Answered on Aug 28, 2014
Accidentally washed my Motorola N136 Bluetooth in the washing machine, it dried out and I put it on the charger and all it's doing is blinking red.....? Is it a lost cause?
Irene- Yes it may not be salvageable. Electronics and water do not mix. Mark Motorola Support
8/27/2014 11:24:58 PM • Motorola... • Answered on Aug 27, 2014
Motorola H710 I can not hear
You can try to delete the H710 out of your HTC's history. Then power the phone off and on again. Then go back through the pairing process to see if it improves. You can also try to reset the headset.
7/9/2014 4:21:24 PM • Motorola... • Answered on Jul 09, 2014
0answers
Motorola Mobility H710 Bluetooth Headset Logo
310 questions posted
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Radio Communications
Most Popular Question
motorola h721 keeps blinking red
  • Radio Communications
