20 Most Recent
Samsung LN37A550P LCD TV Questions & Answers
Washed out picture on LCD TV
Contact the nearest authorised service center for Samsung for details. Repair cost might be under $200.
6/6/2012 4:37:24 AM •
Samsung...
Answered
on Jun 06, 2012
SAMSUNG TV HAVE POWER BOARD PROBLEM
Gamble? a lot of symptoms thought to be power board are not there at all.Correct method for someone with knowledge is check all voltage into and out of the power board ---other wise you might just as well get a dartboard out and throw things or parts at it and hope........
4/18/2012 11:31:52 PM •
Samsung...
Answered
on Apr 18, 2012
I have a Samsung LN37550A
U can't buy the T-CON board in any stores in anywhere in the world because this T-CON board it is not buy able it new u only can buy it as a salvage tv PCB board only.This T-CON board u can buy it as refurbish board only.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
1/2/2012 2:07:54 PM •
Samsung...
Answered
on Jan 02, 2012
I have had a ln37A550P3
This is problem of lcd panel (screen) that need to be replaced but would cost approx new tv price.
Below two sample clips indicate similar problem in lcd tv.
Hope these info will help.
Thanks.
6/24/2011 10:40:08 PM •
Samsung...
Answered
on Jun 24, 2011
I have a 2.5 year
The power supply is going bad, if you take the back off you probably will see a couple of bulged caps that need replaced ( electrolytic caps ), or just buy a new power supply and replace it. The picture is getting dark because the voltage is going down do to bad caps.
1/7/2011 1:24:05 AM •
Samsung...
Answered
on Jan 07, 2011
Will not turn on. standby blinking
hello.
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
9/30/2010 11:45:48 PM •
Samsung...
Answered
on Sep 30, 2010
What type of tv can
hi
Africa PAL broadcast to be abandoned by 2011; is converting to DVB-T; voltage is 230 volt 50hz so you have to ask dealer for those specs
9/29/2010 2:38:55 AM •
Samsung...
Answered
on Sep 29, 2010
Black screen after 30+ minutes of viewing after HD satellite upgr
Plug any other video source like dvd player in tv HDMI and check its performance, if tv stays On and does not show any problem after 40 minutes that means tv is just fine and HD satellite seems cause of problem.
Same test for HD Sateelite, hook it with any other tv that has HDMI input just to confirm it.
Above said process will narrow down problem and will confirm what unit is cause of problem so it can be fixed. Right now there is confusion as two units are involved.
Hope this info will help you.
Thanks.
7/22/2010 1:14:09 AM •
Samsung...
Answered
on Jul 22, 2010
