20 Most Recent Kenwood KVT-512 Car DVD Player Questions & Answers
no you must send her us dvds
Kenwood KVT-512... | Answered on Oct 16, 2019
Blue wire is your amplifier remote or power antena, if you ground it and turn the radio on you burn somethin hopefully j6st a fuse.. You did check the fuses, when in doubt the chassis of the radio is also your ground.
Kenwood KVT-512... | Answered on Mar 07, 2018
do you still ned the intructions on how to install your kenwood kvt-512??
Kenwood KVT-512... | Answered on Sep 10, 2014
try resetting it
Kenwood KVT-512... | Answered on Sep 09, 2014
kenwood.com/cs/ce/mm/firmware/2008/eng.html
this is the firmware update I used to get my Ipod to work on my kvt 512
Kenwood KVT-512... | Answered on Aug 04, 2014
you have to go to the kenwood site and download the firmware update go to this page http://www.kenwood.com/cs/ce/mm/firmware/2008/eng.html
after you download the file unzip it and burn it with either nero or roxio, as a data file insert the cd on your kvt-512, if it reads DISK ERROR, press the reset button on the front of the stereo, once the screen comes back up select the DVD function, the system update should start from there. let it finish once it does then you'll be able to plug in your ipod. oh and ofcourse for this you should know that you need the ipod adapter, depending on what you want to do with it for instance i have the KCA-iP300V which allows me to view videos from my ipod as well.
i sometimes have the same problem it says do no disconnect when it should show the kenwood logo
try restoring your ipod from itunes
I just spliced the brake wire into my cigarette lighter positive wire to provide the voltage necessary to bypass the parking brake requirement for video. Worked like a charm. It takes almost no voltage to bypass it. Even just licking your fingers and holding the bare wire allows video to show.
Kenwood KVT-512... | Answered on Jul 17, 2014
Kenwood KVT-512 Car DVD Player Logo
176 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
como le hago para ponerle
  • Car Audio & Video
