20 Most Recent Samsung 50 in. Plasma TV Questions & Answers
The Samsung brand is the most universal remote compatible tv out there, sounds like either a neighbor or even someone in your own home has a Samsung product that will work on your plasma. for example if someone within range has a Samsung dvd or blue ray player the volume up and down button will work on the Samsung tv also.
Samsung 50 in.... | Answered on Sep 23, 2019
Hello there,
Here is the link to the manual you are looking for:
http://downloadcenter.samsung.com/content/UM/201003/20100324092111375/BN68-02638A_00Eng_0304.pdf
Thank you for using fixya
Caseytech
Samsung 50 in.... | Answered on Jul 12, 2019
http://www.partstore.com/Part/Samsung/Samsung/BN9612707A/New.aspx
It is BN9612707A
Samsung 50 in.... | Answered on Mar 05, 2019
Search Results
    Remote Control Codes
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    ... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...‎Guide to Programming the ... - ‎Download the Manual - ‎8 Device Learning Jumbo ...
    Remotes - Device Codes - HiFi Remote
    www.hifi-remote.com/codes-tv.shtml
    TYPE, BRAND, CODES ... TV, Emerson, 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, ... TV, Samsung, 0019, 0060, 0030, 0056, 0178, 0032.
Samsung 50 in.... | Answered on Dec 26, 2018
It is a Samsung and that means power supply issues.
Samsung 50 in.... | Answered on Jan 30, 2018
i did come across this problim, you gonna have to do the next step. unplug the button pc on tv that control youre volume,channels ext. but you gonne have to use youre remote to see if youre problem is solved. i run my tv only from remote, after this problem you got.
Samsung 50 in.... | Answered on May 04, 2017
You have a shorted main board in the TV, it is more expensive to repair this than to replace the TV at current TV flat screen prices. Also I suggest the brand Vizio, it has the bet reliability ratings of any brand hands down.
Samsung 50 in.... | Answered on Apr 03, 2017
Probably power supply failure that requires more than replacement of a capacitor to correct
Samsung 50 in.... | Answered on Oct 18, 2016
That's a a very vague question. One possibility is that you need to plug it into power. Another possible issue is that the outlet you plugged it into doesn't have power itself.
Maybe the video feed you are using is sending a black screen. Is there any indication of power on the TV?
Samsung 50 in.... | Answered on Oct 16, 2016
Sustain board fault. Check and replace the faulty one. Check the electrolytic capacitors at these boards. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Samsung 50 in.... | Answered on Jul 24, 2016
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Samsung 50 in.... | Answered on Jun 25, 2016
Samsung 50 in.... | Answered on Jun 01, 2016
New Samsung HDTVs use the GREEN RCA input for the yellow RCA video cable, plug it in there. Select the AV input on the TV. For sound, connect white RCA cable to white RCA input on TV.
Samsung 50 in.... | Answered on May 15, 2016
ON THE EXTREME LEFT SIDE OF YOUR TV FACING BACK OF TV WITH COVER OFF THERE ARE TWO BUFFER BOARDS UPPER AND LOWER WITH WITH MANY FLEX CONNECTERS CLEAN THESE CONNECTERS WITH CONTACT CLEANER UNPLUG FLEX CONNECTER BEFORE CLEANING CONNECTER ONLY DISCONNECT CONNECTERS THAT ARE ADJESCENT TO HORIZONTALE LINES THESE CONNECTERS ARE NOT EASY TO DISCONNECT AND RECONNECT IF THIS DOES NOT SOLVE PROBLEM PANEL IS DEFECTIVE tombou300619_2.jpgtombou300619_3.jpg
Samsung 50 in.... | Answered on Apr 08, 2016
Tcon board or The lcd panel is faulty . Only can confirm by replacing the T con board.
Samsung 50 in.... | Answered on Apr 02, 2016
Samsung  50 in. Plasma TV Logo
359 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
  • Samsung Televison & Video
Most Popular Question
samsung plasma 50 tv purchased in 2007
  • Televison & Video
