20 Most Recent LG 37LG30 37 in. LCD HDTV Questions & Answers
It depends with which digital receiver you own. If it is a free to air then you will need a firmware to unscramble https://surpex.ecwid.com But if it is subscription receiver then contact your service provider or use the software above at your own risk. https://surpex.ecwid.com/
cr-health-inlinehero-binge-watching-eat-healthy-0518-14e3eev1rufyta1kbdjftc1a-2-0.jpeg
LG 37LG30 37 in.... | Answered on Jun 09, 2019
Necesitarias que cambiar el circuito que recibe los comandos del control remoto;
Abre el enlace y ahi encontraras la parte que necesitas:
https://www.tvparts.ca/tvdetail.php?id=6393
LG 37LG30 37 in.... | Answered on Dec 30, 2017
Take it back to the shop and exchange it for one that works, make sure it works before you leave the shop
LG 37LG30 37 in.... | Answered on Oct 15, 2017
...accidentally pressed enter key to line-wrap sentence? :)
LG 37LG30 37 in.... | Answered on Oct 11, 2017
power board failed check the main board the 5 volt side may have a few capacitors blown. check all of them as usually when 1 starts to go rest can follow don't cost much to replace. the ones next to the heat sink are first to start to wear out, use the ratings that are on the old capacitors and replace the same 105c temp rating. and rating to failed capacitors, you will see the faulty capacitors they will have blown bowed tops or a liquid on the bottom of them
LG 37LG30 37 in.... | Answered on Jun 21, 2017
The problem is bad electrolytic capacitors on the back lights power invert board, you need to open the back cove up to change the capacitors.
LG 37LG30 37 in.... | Answered on Apr 26, 2017
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/
LG 37LG30 37 in.... | Answered on Nov 05, 2016
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
LG 37LG30 37 in.... | Answered on Mar 20, 2016
Sounds like a bad HDMI i/o board, I have it happen on my receiver before. Try different cables? Try different devices?
LG 37LG30 37 in.... | Answered on Dec 24, 2015
Here is a link on how to put it on. Removal is just the inverse.
LG 223000 Owner Manual Stand Installation
LG 37LG30 37 in.... | Answered on Jul 20, 2015
Try a hard reset. If it do not help you, its main board is faulty, and should be replaced. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
LG 37LG30 37 in.... | Answered on Jul 19, 2015
your owners manual doesn't show a listing for programming any cable boxes. your particular transmitter apparently has no cable button operation.
see the following web site for the download of your manual & then the listings for codes for various sources begin on page 124
LG 37LG30 37 in.... | Answered on Mar 12, 2015
Most TVs do not have Bluetooth. Use cables to connect to TV.
LG 37LG30 37 in.... | Answered on Feb 22, 2015
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
LG 37LG30 37 in.... | Answered on Aug 01, 2014
hi there is a video on youtube showing you how to enable you to use the usb hope it helps
regards
shaun
LG 37LG30 37 in.... | Answered on Mar 17, 2014
NO... check and see if all 4 bolts on bottom of stand are tight. IF it is tilted and tight, remove the stand from the internal slide, re install. Sometimes it gets lodged behind the proper mounting point.
Please leave feedback
LG 37LG30 37 in.... | Answered on Mar 15, 2014
LG 37LG30 37 in. LCD HDTV Logo
262 questions posted
Ekse
RONALD CARTER JR
View Most Popular
  • LG Televison & Video
Most Popular Question
lg lcd hdtv hit lighting try repair
  • Televison & Video
