20 Most Recent Samsung LN26A330J LCD TV Questions & Answers
How do i get my remote control to work?
Maybe check the batteries or clean the remote from dust inside
5/23/2013 3:29:28 PM • Samsung... • Answered on May 23, 2013
0answers
My tv will not come on
It is in shutdown and most likely a power supply related issue.
6/27/2012 12:00:21 AM • Samsung... • Answered on Jun 27, 2012
Tv not working
power supply issue or related to something pulling the supply voltages down.
6/26/2012 11:24:50 PM • Samsung... • Answered on Jun 26, 2012
I can only able to
When you scan for channels, make sure you choose "cable" for the setting under the "Antenna" tab.
channel --> antenna --> choose cable
This should let your TV show more channels. Most cable companies issue cable boxes now a days, which you plug into your TV. You usually change the channel by using the remote for the cable box.
Hope this helps
3/13/2011 7:28:29 AM • Samsung... • Answered on Mar 13, 2011
TV has sound but no
The capacitors all looking good on which board? You need to find out when you do not have picture, are you still geting the backlights on, this is important to narrow down the problem. Please read my guides to understand what it takes for the LCD flat panel TV to work, by the way, bad cap can look normal but can have high ESR or low capacitance than the spec.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board. if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having. If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on: Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series. Please post back what you find.
3/11/2011 4:02:12 AM • Samsung... • Answered on Mar 11, 2011
I just bought a samsun 40 inch tv and I wanted to
Yes, you would need a dvd player or some sort of additional media player. They have alot of different kinds out now. You can even use your cable box to order movies, or you can even use a device that will stream movies instantly such as netflix.
3/2/2011 1:24:49 AM • Samsung... • Answered on Mar 02, 2011
0answers
The television shut off all of a sudden and now
possible defective power supply
5/28/2010 7:36:50 AM • Samsung... • Answered on May 28, 2010
Monitor off but power light on after power shut
IF IT IS THE SAME MODEL I AM THINKING OF,YOU CAN GO IN TO YOUR MENU AND IT WILL HAVE 3 DIFFERENT SETTINGS.{1.OFF,2.LIGHT ON WHEN ON STANDBY,OR LIGHT ON WHEN TV IS ON.I HAVE MINE OFF.
4/24/2010 3:31:53 AM • Samsung... • Answered on Apr 24, 2010
2answers
What are the locations for the capacitors on the
All the capacitors will have location numbers printed on the bottom and top of the circuit board next to them like C18 etc--the values of each will be printed on each capacitor--as well as one side of each will have a strip with - which means it is the negative side of the cap and the other side will be the + or positive side--look for ones that are puffed up on top---see attached photo of a new and good cap--the silver top with the creases should be perfectly flat.
Any bad ones should be visible to the naked eye.
Let me know what you find---if you find puffed up ones they will be marked also with a value like 1000 mfd (microfarad) at 10 v (means the cap is rated at 10 volts.)
If you find bad ones it is a good idea to replace with a higher voltage rated cap of the same value--it may present a small problem as the higher the voltage rating is the bigger the part will be.
The reason (if you have puffed up ones) they fail is because too low a voltage rated cap was used when the set was made---saves the company who makes the sets a few cents on each part.
Let me know if you have questions of need advice.
SD TECH
note the gray band on the left side--negative lead (each has 2 leads) is indicated that way.
2/13/2010 1:38:01 AM • Samsung... • Answered on Feb 13, 2010
Samsung ln26a330j tv has audio but lines up and
sounds like the pic is going bad.
10/17/2009 8:29:51 AM • Samsung... • Answered on Oct 17, 2009
How do i connect my
It depends on what outputs your DVD player has and what inputs your TV has.
If your DVD player has HDMI outputs and your TV has a HDMI input then you will need to purchase a HDMI cable and connect the 2.
If either your DVD or TV does not have HDMI then you will need to move on to either a component video cable which has 3 cables on the end which are colored red, blue and green. You will also need to connect for audio which is a cable with 2 colors, red and white.
There are also s-video and the regular old way of connecting which is a 3 cable design which has a yellow end for video and a white and red end for audio.
If you need any more help or can offer more info on what connections your TV and DVD player have then I would be happy to help.
1/12/2009 7:14:31 AM • Samsung... • Answered on Jan 12, 2009
My samsung ln46b610a5fxza picture started to have magenta and green and red vertical lines appear on the screen and now they won't go away
The problem is the LCD panel went bad, it can't be repaired, you have to replace it.
1/16/2018 12:19:22 AM • Samsung LN... • Answered on Jan 16, 2018
Samsung LN26A330J LCD TV Logo
21 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
tv will not come
  • Televison & Video
