20 Most Recent
LG 20LS7DC 20 in. LCD TV Questions & Answers
Screen on LG goes to black right after turned on.
It looks as if the backlights are being switched off at start up, this will be due to a fault either with the inverter board or a fault with the screens backlights which would mean the screen needing replaced. Contact your repair centre to have an engineer give you an estimate on the cost of repair.
No picture LG 20LS7D
2 680u/25 caps explode in the p.s. caused by underrated power MOSFETS. Replace the caps.
LG 20LS7DC POWER INDICATOR BLINKS 5 TIMES, CHANNEL
Normal
0
false
false
false
MicrosoftInternetExplorer4
st1\:*{behavior:url(#ieooui) }
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Ur power supply board is dead, u know basic electronics’ and soldering?
Most of the times, the power suppply board just have dead leakages gases
capacitors.These capacitors alway bulges up on it top,or puff up on it
top.Replaced these gases leakages capacitors will get ur tv power stable,and
work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole
rerfurbish power supply board for the replacement.
20" lg LCD backlight turns off after about 5 seconds of use.
First, check the power supply for the backlight. It's usually a 24 volt supply. Look for swollen caps. If that is ok, go to the inverter board and inspect for damage, ohm out the inverter transformers. Last is to test out the lamps seperately with an external inverter. If a lamp goes out this way, it is bad and causing the whole backlight to go out.
Black screen on a 20ls7d LCD TV
I work at CNN Have had 6 of these monitors go out in as many months. Take out the power supply and change the 2 exploded 680u capacitors. They're being overheated by the underrated MOSFETs on the reverse side of the board. I'm looking for some substitute MOSFETs that handle power better; but replacing the caps will usually fix the problem. Otherwise replace the supply.
The tv does not turn
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
My 20 lg powers up, red light turns green, but no
You wont want to hear this.....
Green dots on a LCD screen are burnt out pixels and unfortunately are
incurable other than having the TV serviced at a high price. One of the
reasons it is a good idea to get a warranty on these types of TVs is
primarily due to this very problem....burnt out pixels.
Please rate my help++++Thanks for using FIXYA
