20 Most Recent
LG 42PG20 42 in. Plasma HDTV Questions & Answers
Hi
i have
you can't and DIVX is an AVI format. MKV is an entirely different encoding format. There are no TVs or DVD players that support MKV. Also you will not get a DVD player that will paly BlueRay. DVD and BluRay require 2 different lasers on the drive to read the format so your software will not allow for this through a USB or hdmi either. You have what you have and there is nothing you can do aside from using the PC the movies were pirated from and connect it to the TV.
I own a LG Plasma
The USB port on the TV might not have enough power to power the external hard drive.
Can you try putting a movie on a USB memory stick instead, and see if that works?
Lg 42pg20 Plasma Will not turn on
If there is no LED burning to indicate there is power than the power supply is faulty.Repair is not verry easy to do with these complicated power supply's.
Message is no signal
then you need to hook up something to it .. HDMI unit dvd player or an antenna to the co-ax input then do a channel search.
IR blaster doesn't work, why?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Expert
code for lg 42pg20a
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful.
Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
