20 Most Recent
Samsung LN40A450 LCD TV Questions & Answers
Power faulty
unfortunately samsung wont produce full schematics since they want board replacement repairs only. But you might get some free tech support from the guys at
www.tvrepairworld.com
I have a Samsung LN40A450 LCD TV that is only a
I will explain how to:
basically in all LCD monitors have two circuit boards (power supply board and system board)
- After you open you will see the two boards are
- You see a board that has a socket for the power source. wrote that the board we're looking for (power supply board)
- Remove all cables connected to the board and take out the board. (get noted before you unplug it)
- Now you see it components on board, we looking for capacitor.(see picture below)
- Looking for damaged capacitors, physically you will see a capacitor on the top like a bloated (see picture below)
- Replace the damaged capacitor with the same value that you can see on the surface of the capacitor. (In this step you need any soldering tool)
My advice: replace capacitors with higher voltage, like 10V replace with 16V or 25V will be fine.
Have a 40 inch Samsung flat screen that will not
Your power supply needs repaired. You can pay someone to do it locally... or you can do it yourself. I have a tutorial on this repair published on this site. Check it out if you like. I hope this was of some assistance.
My samsung LN is almost three years old, and
in the menu under setup there is a factory reset when you do this it puts the tvback to the way it was when it came out of the box we have knoticed that for some reason hdmi connectors are subject to surge and power problems not exactly sure why but a main board replacement might be needed
