20 Most Recent
Panasonic Viera TC-37LZ85 LCD TV Questions & Answers
Why does it fail to turn on??
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Stuck on channel 1 is there a fix for this problem?
If your remote is ok and not responding to manual controls, guess your TV is defective. I'm not a TV tech so can't tell you what part you should replacem, so if you reall coudn't do theis repair job yourself, my best advice is to send it to a repair service
How do you remove the self check on a panasonic
Hello: This procedure will bring up the self test screen and reset the unit to factory settings for you.First produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
