20 Most Recent Panasonic Viera TH-42PZ80U Plasma TV Questions & Answers
2answers
Trying to change Panasonic settings on my model thc42hd18 tv so that it will connect to my WiFi router so I can view internet on it. Cant find Panasonic settings to do it?
It is 13 years after the end of production. We didn't have routers then! There is no wifi convertor in your old Panasonic TV. It won't work without a computer interface between the two.
1/13/2022 2:33:44 PM • Panasonic Viera... • Answered on Jan 13, 2022
3answers
My panasonic viera tv red light blinking 5 times and it wont turn on
7/18/2019 10:17:53 AM • Panasonic Viera... • Answered on Jul 18, 2019
I have a Panasonic DMR-BW780
Ive got this problem too. Anyone found a solution?
4/20/2019 6:40:56 AM • Panasonic Viera... • Answered on Apr 20, 2019
No screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
12/27/2018 8:32:32 PM • Panasonic Viera... • Answered on Dec 27, 2018
Th42px60u
Most likely is the power board,so I hope you got a good one! The next would be a short on the SC board. The main digital board could be defective in mis diagnostic. Disconnect the SC board and see if the blink code changes. if it changes,the main board is good. If you have a good power board,I vote for a short on the SC board to be checked
2/12/2018 2:14:04 AM • Panasonic Viera... • Answered on Feb 12, 2018
Half of the screen is black
Check the left connector from the Tcon to the panel, if its ok replace the board
12/24/2017 8:02:55 PM • Panasonic Viera... • Answered on Dec 24, 2017
3answers
Want to turn off audio description off on my
iv got a panisonic i dont know if its the same but i click on the options buttion witch takes me to the options menu
then it says ad in the multi audio/ad box change this to eng
11/15/2017 11:47:57 PM • Panasonic Viera... • Answered on Nov 15, 2017
Panasonic TH-42PZ80U doesn't turn on. 10 time blinks
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
10/27/2017 12:20:20 PM • Panasonic Viera... • Answered on Oct 27, 2017
Ditto for my Panasonic plasma TV - The set
Did you accidentally change color settings? Or maybe viewing aspects?
7/6/2017 3:21:55 AM • Panasonic Viera... • Answered on Jul 06, 2017
I have a 42 inch panasonic plasma tv, I have great picture and sound on hdmi input only
From a quick look at the tv spec it would seem to cope with most inputs so I wonder if it may be due to input type selection. Mine on some inputs have sub options on its inputs which would be in the screen menu (mine has rca sockets and can become component or normal video input). You say you can hear sound but no picture which sugests there is a signal of some sort (tv's and video's inputs become live when a video signal is present but if its poor in some way will not show) but allow sound through. If the game is old then it may not conform to modern standards so present a blank screen. its hard to say what may be the problem but I think input selection or an incompatible signal looks to be a possible answer (if you have your plug ins correct) Hope this helps.....
7/2/2017 10:45:26 PM • Panasonic Viera... • Answered on Jul 02, 2017
How to download panasonic th-42pv8d service manual free
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
1/27/2017 9:40:37 AM • Panasonic Viera... • Answered on Jan 27, 2017
2answers
Panasonic Plasma TH-42PZ80U HDMI do not work after lightning storm
I don't have a solution, unfortunately, but your problem is nearly identical to mine. It even seems to have happened on the same date (7/27/12)! Do you live near Dener by chance? Anyway, we have Direct Tv, and ended up with 2 fried HD DVR boxes and 2 TVs on which the HDMI connections don't work after lightning hit close to our house on 7/27. Those boxes were replaced, as was part of the Direct TV dish. The only difference is, whereas on one TV component connections (red/white/yellow cables) allowed the TV to work normally, on the other (my 50 inch Panasonic Plasma TCP50S30) even the red/white/yellow cables did not work. Now I'm scouting the net for tips on what else to try before I possibly have the Panasonic looked at, which I am hedging on doing since I got it for only $600 new in the first place. Have you found out anything else since you posted this? Good luck to you...
12/27/2016 6:24:52 AM • Panasonic Viera... • Answered on Dec 27, 2016
Where is the input on the Panasonic Viera remote?
It is inside the remote. You have to open the remote to get access to it.
10/5/2016 2:55:56 AM • Panasonic Viera... • Answered on Oct 05, 2016
My Panasonic tv went from black to snowy. What do I do to fix it
well snow pix is telling you that all your video ckts are good , and if you get snowy sound then your sound ckts are good , now you need to look at your tuner ckts , but first ck your cables and connections , substituting with a known good cable is the best way of testing it
10/4/2016 2:24:56 AM • Panasonic Viera... • Answered on Oct 04, 2016
HELLO MY TV DONT OPEN UP, THE RED LIGHT IS FLASHING
What do you mean by open up?
9/8/2016 11:13:22 PM • Panasonic Viera... • Answered on Sep 08, 2016
Panasonic Viera TH-42PZ80U Plasma TV Logo
717 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VIERA Panasonic
  • VIERA Panasonic
Most Popular Question
connect netflix
  • Televison & Video
