20 Most Recent Panasonic Viera TH-50PZ80U Plasma TV Questions & Answers
2answers
My Panasonic won't turn on. Red light just blinks.
contact to compiter
5/1/2022 4:47:09 PM • Panasonic Viera... • Answered on May 01, 2022
4answers
Panasonic TH-50PZ80U tv, error- 2 blinks
1. Reseating the connector P25 may solve the problem. If it does not.
2. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
3. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown.
10/20/2019 2:50:16 PM • Panasonic Viera... • Answered on Oct 20, 2019
Hdmi on tv loses signal
Try another HDMI input on your set and see what happens.
7/26/2017 1:47:22 AM • Panasonic Viera... • Answered on Jul 26, 2017
7 blinks of death Monday
just like crt tv units, plasma are old technology besides that they use enormous amounts of power and are now a waste of time in repairing If you leave it powered on , that is alright as the main destroyer of electronics is the constant on/off operation as the temp changes of the components is the problem However knowing that it uses probably 100 times more power than a led unit, , you are having problems with it and knowing the price of parts , I would recommend considering a newer more economical unit of a quality brand
3/16/2017 3:01:20 AM • Panasonic Viera... • Answered on Mar 16, 2017
PANASONIC TH-58PZ700U 6 BLINKS -
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
8/29/2016 2:14:28 AM • Panasonic Viera... • Answered on Aug 29, 2016
I have a panasonic 50 inch plasma th-50pz80u.
try to check power supply look for swollen capacitor it is the common trouble of plasma and lcd.
7/9/2016 3:20:54 AM • Panasonic Viera... • Answered on Jul 09, 2016
Remote control codes for Panasonic tv
CALL YOUR CABLE PROVIDER
1/21/2016 11:08:56 PM • Panasonic Viera... • Answered on Jan 21, 2016
Panasonic TH-50PZ80U plasma wont turn on
YOU MUST BRING THIS TV TO A REPAIR CENTER EXPECT AT LEASE 450,00 AND MAYBE MUCH MORE THERE MAIN PROBLEME IS SC BOARD AND OFTEN SD SU AND WORSE PANEL !!
12/6/2015 6:37:24 PM • Panasonic Viera... • Answered on Dec 06, 2015
Color problem blue is dominant
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
11/20/2015 1:11:04 PM • Panasonic Viera... • Answered on Nov 20, 2015
Power button light blinks 10 times. TV will not turn on
11/4/2015 11:17:34 AM • Panasonic Viera... • Answered on Nov 04, 2015
We had a lightning storm sand since then my TV will not work. Power light comes on but no codes are given to try to diagnose.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
7/14/2015 3:00:11 PM • Panasonic Viera... • Answered on Jul 14, 2015
I can't connect to netflix streaming. I have Verizon Fios Wi Fi but I can't find where to put in the Network number or the password using the TV menue. Please help me. THank You!! Al Gordish
The tv is on in HDMI and the Apple tv on. When I turn my TV on an Apple comes on the screen and it takes awhile to establish itself, it disappears on again and the circle goes around until on the screen from the top >top films>Films>TV programs>music>iTunes >computers,next line netflix I click on Netflix ,on the screen they ask Who is watching Netflix answers:kollagu,kids,sign out. it seems to me that you have not succeeded in the registration phase. I have not counted how often I failed. I can not lead you through it because we do not have an official access to Netflix in this country. So we have to go a backway to get to it. i am sorry if I have misunderstood your question, but know how I can use my Netflix kolbrun
2/7/2015 1:57:15 AM • Panasonic Viera... • Answered on Feb 07, 2015
Panasonic Viera TH-50PZ80U Plasma TV Logo
345 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VIERA Panasonic
  • VIERA Panasonic
Most Popular Question
pink vertical line in center screen th
  • Televison & Video
