20 Most Recent
Panasonic Viera TH-50PZ85U Plasma TV Questions & Answers
Hello i have a Panasonic
Almost sure you have a power supply issue. Or it could be a Y sustain board which for my set is no longer available!!!
My tv panasonic viera
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. ..
Panasonic plasma tv doesn't turn on, red light flickers twice
hi look for any swollen capacitors, also plasma's do suffer from poor solder joints on the power board, so check for any rings around the solder pads, test the voltages on the white connectors with a meter the voltages will be written along the connector,thanks
shaun
10 red blinking lights on my Panasonic Plasma TV,
This is a power supply issue - found a company that has used power supplies, they sell them for $60.00. We recommend a professional install the board because the voltage needs to be adjusted after the install or you could damage something else. The high voltage in the set can KILL you soe be very careful. The web address for the PS board is plasmafix.com.
12 blinks on th-p42x20m
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "
Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Picture quality deteriorated
Most like one of the scan drive boards is failing. It would need troubleshooting to determine which board is weak.
Light switch affects picture source
hi your tv may be set up on eco mode, there is a light sensor built into
your tv this detects the room light and adjust the picture to suit the light hope it helps
regards
shaun
