20 Most Recent
Samsung LN52A650A LCD TV Questions & Answers
Samsung LCD LN52A650AF - Glittery Red Green Screen Pixelations that moves around with changing figures on the picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
5/14/2017 1:47:30 PM •
Samsung...
Answered
on May 14, 2017
How do i replace bulb in Samsung TV model LN52A650
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board....
1/4/2017 3:34:23 AM •
Samsung...
Answered
on Jan 04, 2017
When trying to turn my tv on the unit chimes then there is a click then the chime then a click & this cycle repeats 10 or 12 times until the tv finally powers up. Is this a power supply problem?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
4/6/2016 4:40:53 PM •
Samsung...
Answered
on Apr 06, 2016
Can't power on TV occasionally
It is possible that the conductivity of a power diode is diminished after a period of time causing the unit to receive just under the needed current to function. Test the resistance of internal components after periods of tine or seek manufactures assistance.
10/30/2015 11:19:48 AM •
Samsung...
Answered
on Oct 30, 2015
To The Knight: followed your advice, nothing came up for my samsung LN52A650A1FXZA. will keep searching the problem.
Horizontal line problem is usually related with T'Con board itself. In rare cases, with panel too. There is details about this, at one or tow among the posts with the blog I've pointed out to you. I do clearly recall that, I've seen it there. It is a site, has more than 400 indexed pages on Google. a helpful one too. I've pointed out to many others, and most of them did find solutions to their problem there. I do get their responses too; by Fixya.
Just understand, an LCD TV is working mearly by some capacitors, and some users trusted as it is.
Contact any service technician. It will be the best.
11/16/2014 4:29:17 AM •
Samsung...
Answered
on Nov 16, 2014
TV loss sound and make funny noise
The audio output section circuit should be troubleshooted. In most cased, the audio baord need replacement. Check its speaker too.
5/14/2013 12:57:52 PM •
Samsung...
Answered
on May 14, 2013
Tv real slow about powering up
Happened to me. I called Samsung and they sent a serviceman out. I can't remember what the problem part was called but it was a problem they evidently knew about and fixed it for free...the first time. It hasn't done it again (knock on wood)...so you should call them if it's a Samsung TV.
2/24/2013 2:22:18 AM •
Samsung...
Answered
on Feb 24, 2013
