20 Most Recent Fostex MR8-MKII - 8 -Rack Portable Compact Flash Recorder MR8MKII for PC Questions & Answers
Foxtes MR-8 track bouncing problems
You are leaving at least one track open to bounce to aren't you? And you should leave 2 open if doing stereo tracks. More information would be helpful.
5/25/2015 9:31:19 PM • Fostex MR8-MKII... • Answered on May 25, 2015
2answers
Volume low when i transfer to my pc?
I find everything I play on my PC is at a lower volume than when played on another system, despite everything being at max. Dunno how to overcome that
4/22/2015 2:27:52 AM • Fostex MR8-MKII... • Answered on Apr 22, 2015
How to reset a Fostex MR 8 multitrack recorder
http://www.fostexinternational.com/docs/downloads/pdfs/mr8_owners_manual.pdf
4/19/2014 11:54:28 PM • Fostex MR8-MKII... • Answered on Apr 19, 2014
Does the FOSTEX MR 8 have an internal lithium battery
http://www.fostexinternational.com/docs/downloads/pdfs/mr8_owners_manual.pdf <--- refer to page 17 for batteries
4/19/2014 11:53:47 PM • Fostex MR8-MKII... • Answered on Apr 19, 2014
My Computer says that the
Go to site
http://www.fostexinternational.com/docs/tech_support/multitracker_software_updates.shtml
download your driver for your product version.
Thanks for using FixYa.
5/17/2011 5:22:07 PM • Fostex MR8-MKII... • Answered on May 17, 2011
How do i prevent gliches?
Keep the noise out of it with filtering,a good iron ring around the power cord is a good cheap fix
2/15/2011 6:51:54 AM • Fostex MR8-MKII... • Answered on Feb 15, 2011
HI WHEN DOWNLOADING MY RECORDINGS TO MY DELL 1720
Ensure your Master output volume is at an acceptable level when recording. The machine will only save audio at the levels which it is recorded.
Also be sure to adjust levels accordingly when bouncing tracks down to one channel. I ussually prefer to set the EQ for these tracks to flat (or zero), as you will have much better results doing the EQ in final mix.
1/7/2011 2:02:08 PM • Fostex MR8-MKII... • Answered on Jan 07, 2011
0answers
I have a Fostex mr8 digital multitracker and I was
system upgrade
12/20/2010 10:18:44 PM • Fostex MR8-MKII... • Answered on Dec 20, 2010
How to fix error code 0d f006
Uninstall or update your device.Here are some updates:
From here you can download the latest software revisions.
12/9/2010 4:44:38 PM • Fostex MR8-MKII... • Answered on Dec 09, 2010
I am trying to use a 4 MB compact flash card in my
if you have the red mr8, it cant be done
digitally it stops at 128 minnutes
the mk2 will take anything
i have a 4gb and i get 480 minnutes
11/19/2010 10:36:41 PM • Fostex MR8-MKII... • Answered on Nov 19, 2010
My Fostex MR8 messages HDD disk full and it seems
If I were you I would pull the hard drive out, hook it up to an external enclosure and try to access via windows.
Is that something you could do?
10/16/2010 9:27:01 PM • Fostex MR8-MKII... • Answered on Oct 16, 2010
I just got a 2gb card for my mr-8 (the first Red
please solve the victim software counterfieting
10/12/2010 1:43:03 AM • Fostex MR8-MKII... • Answered on Oct 12, 2010
Importing track to Fostex MR-8MK 2
I just got an MR-8 and had the same problem. Google and download Wav Manager...convert your files to mono (.wav) or else it won't export. I searched everywhere for several days and stumbled upon the solution woohoo!!!
7/26/2010 12:29:23 AM • Fostex MR8-MKII... • Answered on Jul 26, 2010
How do you check firmware version or update the
GO to USB, set Card Protect=Off
Then start up USB Device Mode
The Fostex will come up as an external drive. Copy the .MOT file over to the root directory (where all the folders for your songs are).
Using Windoze' Safely Remove, (or Mac's Eject) disconnect the Fostex from the computer.
Disconnect the MR-8 from the USB cord.
Now hold down the STOP key and press Enter at the same time. This will cause a new option, the Service Menu, to appear. Click Enter, scroll on down to Version Up. Hit Enter again, and you'll see your file (MR8MV105.MOT in my case). Click Enter again, and it will ask you to confirm. Follow the instructions; press both RECORD and ENTER at the same time to continue.
Then you'll see File Loading, then Flash ROM erasing, then Flash ROM writing, then Completed, please hit STOP key. Then turn it off at the switch, and back on.
Assuming all went well, when you hold down the STOP and press ENTER, the Service Mode will come up again. Press ENTER, then press ENTER again (for Version) and confirm.
Enjoy!
7/10/2010 8:52:50 AM • Fostex MR8-MKII... • Answered on Jul 10, 2010
When i download an owners manual from fostex, i
You need to make sure you are opening the file with the correct program. Try opening your doc or txt files with either WORDPAD or MSWORD.
3/28/2010 4:16:05 AM • Fostex MR8-MKII... • Answered on Mar 28, 2010
3answers
Mr 8 card says Error
This error is due to the corrupted data in the card,
Please get your Card formatted by any external medium.after formatting all the corrupted data will get erased.
check out,this will help.keep updated.
2/28/2010 2:09:04 PM • Fostex MR8-MKII... • Answered on Feb 28, 2010
Fostex MR8-MKII - 8 -Rack Portable Compact Flash Recorder MR8MKII for PC Logo
56 questions posted
Popular Products
Top Fostex Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Fostex Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Fostex Computers & Internet
Most Popular Question
am trying use 4 mb compact flash card in
  • Computers & Internet
