20 Most Recent
Acer P191WBD LCD Monitor Questions & Answers
My acer monitor p191w will
Connect the monitor to a different computer, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your computer really is "sending" a video-signal through the "data" cable. If not, then either the data-cable or the video-card inside the computer is faulty.
Unit starts ok then any where from 30 sec to 1
hi,
Before going to replace CCFL check the inverter of the CCFL. Normally the inverter get faulty. There is possibility that the winding of the high voltage transformer get shorted or its driver transistor may get faulty. check the same
ok
My monitor turns on but
There are two points here.
1. After the monitor turns black do you still see some activity of the PC? Like some noises of the HDD or the HDD light working. If yes then the problem could be with the monitor. (I doubt very much).
2. If no, then the problem could be with the Windows installation. If so the press F8 at boot up and from the black and white menu that you are taken to, select Last Good Boot up or words to that effect. Or you can even select Safe Mode. Let the PC boot up and then in the next phase you can let it boot normally.
While the screen on the P191Wis wide enough, I
Adjust the resolution of the monitor
Control panel / display.
You may need to update your graphics drivers if you have a Graphics card fitted, if you have graphics built onto the motherboard, you need to check your manufacturers support page for the latest driver.
My acer monitor will not play videos in full
Try this.
Disable hardware accelerating on your adobe flash player Settings.
Can be done by Right Clicking the Video and selecting settings
Then uncheck the hardware accleration. Then see if you can play in full screen.
Monitor brighness shuts off
It sounds like the backlight circuits are not working, it can be due to bad power supply.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Monitor don't want to turn on. just blinking. what
Sound like the video card is at fault on your PC it sends a signal to wake up the monitor if this is not present then PC may appear to start the monitor will be in standby but remains blank.
Replace your video card even if the BIOS chip says that it is present this will solve you problem
My new Acer P191W LCD Monitor has a high pitched whine.
The PSU "power supply unit is taken on a lot of noise from the outlet. Can you tell us if you have it streight plugged into to a 120V AC outlet or is it plugged into a strip? The Solution for both is NEW strip i recommend APC or plug it into a strip and check the outlet and make sure its properly grounded this should shore up this problem or the unit itself is going out. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Acer Monitor P191W - how can I remove what looks like a
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
"Input not supported" roaming on my screen
It means that the resolution of the windows is set too high for your monitor. You will have to find some better monitor to connect it to it, and then to lower the resolution, after that, it should be working just fine
Computer screen says no signal
it could be that the monitor is out of range. plug in an old crt monitor if it works go to display options (where you change your background) click on the settings tab and move the res. to 1024x768
Input not supported on my screen
your resulition is set too high. to fix this you need to either change it on another screen if you have one or restart your computer into safe mode. usually in safe mode it will be on the lowest setting and you will have full access to change it from there.
I have a line threw my monotor
Bring or call the place where you purchased it. This should be cover by warrenty (inside 2 months). Call the co. for a RMA, Replacement order. And talk to them about the details. This shouldn't be a big problem.
