20 Most Recent
Canon Pixma iP2600 Photo InkJet Printer Questions & Answers
Canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
My canon printer wont print
Issues with the cartridge are other causes for trouble in your printer. If you have not used your printer for a pretty long time, there's chance for the ink in the cartridge to get solidified, ending up in its damage. The issue could also be caused due to the lack of ink in the cartridges. In order to resolve the issue, you might ensure that you are not keeping your printer idle for very long periods. You could also check its ink level.
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
- If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
- If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
- Remove the material from paper path
- Replace Sheet Feeder Unit
- Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer ForumRe
Ink reservoir full
Heres a canon link for finding your nearest service centre http://www.canon-europe.com/Support/Consumer_Products/services_locator/index.aspx However, you may want to review the following links - which explain how to do the cleaning yourself
Theres a number of solutions on this link http://www.fixya.com/support/t181480-waste_ink_absorber_canon_ip_1600
This is not your exact model - but maybe useful to watch
http://www.youtube.com/watch?v=VVpjqBr7KjU
http://www.youtube.com/watch?v=4IrBdw7el2E
Theres some instructions on this post on how to clean http://www.fixyourownprinter.com/forums/printer/41279 But Beware of causing any damage
Printer does not recognize cartridge
could be a faulty ink cartidge.. try a different one if you have a spare... or even put the old one in, and see if the mesage changes to empty cartridge,,,
Why are pages coming out striped?
There is probably dirt on the rollers or on the paper carrier. You could try running the printer through a self clean first. Go into the printer settings, menu, locate self cleaning and press that.
Ink absorber is full
The absorber needs to replaced in a shop. # QY5-0240-000, A shop needs to do it because they have the software to reset the error, after the absorber is replaced.
THE PAPER COMES OUT BLANK WITHOUT PRINTING.
Make sure you remove the protective tape from cartridge(s). If it's been removed, try running 'nozzle clean' or 'deep clean' (for that cartridge). You can find this in 'Printer properties' on 'Maintenance' page.
Printer wont print
To solve the
printing problem..
# Hold the cartridge upside down, with the
bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the
cartridge on the bottom (where the ink comes out). Wipe the printhead
horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure
the ink is flowing.
# Next, look inside the printer and locate the
carrier that holds ink cartridges. Caution: Make sure the cartridges are not
installed at this point.
1. Look for a shiny piece of metal underneath the
contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and
wipe along the bottom of the shiny metal piece. Note: You may need more than
one swab.
# Reinstall the cartridges, making sure you snap
them correctly into the printer.
Hope this help. Please
Rate My Response! Thanks!
