20 Most Recent Lexmark X4875 InkJet Printer Questions & Answers
I have a paper jam.
Try to open the printer cover to access the cartridge area. Firmly hold the paper jam and carefully remove it from printer. Avoid tearing the paper, if possible. Leave no torn pieces in the printer to avoid future paper jams.
10/3/2011 9:47:01 AM • Lexmark X4875... • Answered on Oct 03, 2011
The language on my lexmark printer is not in
Please follow the steps below carefully:
  1. Rebrick the printer by pulling out power supply, black box where the power cord is plugged in at the back of the printer.
  2. Press and hold the Start (green diamond) and the Cancel (red X) buttons at the same time.
  3. Re-insert the power supply in the printer while still holding down the Start and Cancel buttons.
  4. Release the two buttons when Language Selection appears on the printer display screen.
9/4/2011 9:28:01 AM • Lexmark X4875... • Answered on Sep 04, 2011
My lexmark printer x4875 only
Try to reset your printer to factory default settings. Go to Maintenance -> hit check -> select Reset Defaults -> select first option only to reset factory defaults. Try to make a copy again.
5/3/2011 9:58:46 PM • Lexmark X4875... • Answered on May 03, 2011
My Lexmark Software is adding a new Programs File
What is the operating system of your computer? It could be a conflict of Lexmark software. Disconnect the printer from your computer (if it's connected with a USB cable). Try to uninstall the existing Lexmark X4875 printer software by going to the Start menu -> All Programs/Programs -> Lexmark 4800 Series -> Tools -> Uninstall. Reboot pc when prompted.
To reinstall, use the driver from the Lexmark website available at http://bit.ly/btpHyF. Select your operating system clicking on "change OS". (see sample below)
Then click on FILTER (see sample below)
Then click on the driver under Recommended Downloads. Download, execute the file and follow the instructions in the software.
Thanks.
11/18/2010 1:48:38 PM • Lexmark X4875... • Answered on Nov 18, 2010
The printer screen display is in chinese or other
Incorrect language appears on the display
These are possible solutions. Try one of the following:
Change the language selection during initial setup
After you select a language, Language appears again on the display. To change the selection:
1 Press or repeatedly until the language you want appears on the display.
2 Press to save.
Select a different language after initial setup
1 From the control panel, press or repeatedly to choose Setup.
2 Press .
3 Press or repeatedly to choose Change Printer Default Settings.
4 Press .
5 Press or repeatedly to choose Language.
6 Press .
7 Press or repeatedly until the language you want appears on the display.
8 Press to save and exit.
Note: If you cannot understand the language on the display, see "Resetting the printer to factory default settings" on page 57.
Manual:
http://images.lexmark.com/publications/pdfs/2007/4800/v4924668_en.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
11/17/2010 3:16:57 AM • Lexmark X4875... • Answered on Nov 17, 2010
I lost installation CD so
This is how you can install a printer to be a network printer. Depending on your version of windows determines how your network will work, but for the most part, as long as you have this printer connected to a Windows PC you should be able to set it up to print wirelessly this way.
10/18/2010 11:03:21 PM • Lexmark X4875... • Answered on Oct 18, 2010
Printer was installed but does not operate..gives
Try going to manufactures website and updating your drivers. Look for newest driver and also check if it's compatible with Windows 7. This should help you with an issue. Good Luck
4/28/2010 4:38:19 AM • Lexmark X4875... • Answered on Apr 28, 2010
Paper jam message
on most lexmark printers when it reports a paper jam with no paper it means that the main motor drive has not initiated. open the top lid and stick a q-tip in the sensor that tells the printer the lid is open. turn the printer on and observe to see if any of the feed wheels turn during self tast. if they do not you have a bad motor drive.
10/24/2009 9:14:04 AM • Lexmark X4875... • Answered on Oct 24, 2009
PRINTER CARRIER STALLS
Check printer drive belt for worn out teeth and also ensure that the printer shaft is free of greezeand dirty.
7/13/2009 3:05:17 PM • Lexmark X4875... • Answered on Jul 13, 2009
I am getting a paper jam message but there is no
Check your paper passege sensors, may the actuator is boken or one of sensors is dirt. Use blower to blow off dust.Hope this solves your problem.
7/13/2009 3:00:45 PM • Lexmark X4875... • Answered on Jul 13, 2009
How do i set the time on a lexmark x464
Usually you need to access the embedded web server on the printer by typing the IP address of the printer into your web browser address bar. This will open a window that will have all the settings available.
10/4/2018 10:41:36 AM • Lexmark X Office... • Answered on Oct 04, 2018
0answers
What other possible sftware version is compatable for lexmark x1205 printer please help seems to be outdated but cartridges are still available
go to printer properties in the control panel and click on latest driver
8/6/2016 9:47:49 AM • Lexmark X Office... • Answered on Aug 06, 2016
Lexmark X4875 InkJet Printer Logo
21 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
printer installed but not operate gives
  • Office Equipment & Supplies
