20 Most Recent
OKI C5650n LED Laser Printer Questions & Answers
612: C Toner missing
The toner cartridge might not properly installed. Just try reinstalling or re-insert problematic toner cartridge, after doing it the error should gone.
How do I reset fatal
Oki is forcing you to buy a new fuser. If fuser roller, film and
thremistors are still in perfect shape, reset is possible with new OEM
FB fuse
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Fatal error 182
I expect you have an extra tray fitted. This error refers to this option. Turn the power off and lift the printer off the second tray .Now turn it back on and it should print ok. If so then throw away the optional 2nd tray as it has gone faulty.
OKI c5650 flashing "K drum life" I buy new charge
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
RESET DRUM
TRY THIS
8. Restart printer.
