20 Most Recent Canon Pixma iP4500 InkJet Printer Questions & Answers
3answers
Canon IP4500 repair manual
There are three options for you:1 -- Here is a copy of the manual for free http://www.gondack.com.ar/media/useruploads/files/ip4500-ssm.pdf 2 -- Go to this web page and register for the forum, then post a comment requesting the manual like everyone else and a member will email the manual to you. The last request for a copy of the manual is a few weeks old. http://www.fixyourownprinter.com/forums/inkjet/58346 3 -- Go to the service manual website about Canon (not a Canon site) and purchase a copy for $8.00 USD. http://www.canonservicemanual.com/canon-ip4500-service-manual
7/10/2019 9:44:16 AM • Canon Pixma... • Answered on Jul 10, 2019
Canon Pixma iP4500 InkJet Printer problem: The
Use warm water and a lint free cloth and clean all the ink around the cartridge area. I f that doesn't help I would try a new (not remanufactured) ink cartridge.
6/28/2017 9:44:33 PM • Canon Pixma... • Answered on Jun 28, 2017
0answers
Error 1250
look for a small sensor on you right hand side. it tell the m/c if it is open or close. it migit be stuck.
1/6/2017 5:30:08 AM • Canon Pixma... • Answered on Jan 06, 2017
2answers
Remove print head without power from Canon IP4500
If you have no intention of 'fixing' the one that does not power on, then just dissasemble it. If you take it apart, chances are that something will not line-up correctly when trying to re-assemble it. To troubleshoot the power issue: I would fisrt suspect that the wall power is not getting to the power module, since, I assume, when you say both work it means you used both to run the printer with the bad print head. The power module should be deistributing the power to the rest of the printer. There will be a main circuit board that is the brains of the printer. That will need power in order to drive the print head to center when you open the top.
7/24/2016 8:50:47 AM • Canon Pixma... • Answered on Jul 24, 2016
Header error message print head not installed
5/25/2016 5:56:13 PM • Canon Pixma... • Answered on May 25, 2016
Canon ip4500 problematic with win 64bit - seeking solution
Go to a 64-bit machine on the network and copy the 64-bit driver files to the machine From the 64-bit machine, open Windows Explorer and browse to the 32-bit server Open the Printers dialog seen via Windows Explorer. From the Menu bar, select File > Server Properties, select the Drivers tab and click the Add button. In the Add Driver Wizard, tick the x64 Processor checkbox, and untick the x86 checkbox. Click Next, then click Have Disk and browse to the 64-bit driver on the local 64-bit machine. Complete the Add Driver Wizard. for more help visit CBR Tech Solutions
10/20/2015 8:38:27 AM • Canon Pixma... • Answered on Oct 20, 2015
2answers
I need to download canon pima ip4500 printer
I have provided a link below for you to go to at the Canon support page for your model printer,
Please selct the MAC operating system you have on your computer before downloading the driver.
Follow the prompts and install as instructed by the site and you should be good to print.
It would be advisable to add the Canon support page to your "Favorites" in the event you need to return to the page for addtional information or other software.
Good Luck
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip4500#DriversAndSoftware
4/29/2015 9:02:07 AM • Canon Pixma... • Answered on Apr 29, 2015
2answers
Canon pixma ip4500 cannot install drivers,
Hello how are you. If you install windows 7 when you turn on the USB cable to the driver you downloaded from the Internet.If windows finds himself then the problem is the USB turntable.Call the appropriate Canon printer service.
4/29/2015 9:01:50 AM • Canon Pixma... • Answered on Apr 29, 2015
2answers
Why is the colour in my photographs not printing as they are in my laptop I have added new inks and cleaned the printing heads
Anonymous, there's a whole science of "color management" that you've invoked. First, what you're seeing is truly caused by lack of "calibration" in any stage of your workflow. Your camera takes pictures, and whatever colors it sees are what it sees. Your monitor shows you colors, but there's no standard calibration involved. Your printer prints colors, but it too isn't calibrated to any standard.\ Assume for a minute that your monitor is set up to be a little too dark. You edit the pictures, and lighten them up so they look ok on screen. Now, when you print the picture, it's too light. I've had similar issues, and have ended up purchasing a monitor calibration tool (Color Munki Smile) to calibrate my monitor, software "Profile Prism" to calibrate my printer, and now the prints I get look almost exactly like what I see on screen...
9/11/2014 8:27:51 PM • Canon Pixma... • Answered on Sep 11, 2014
How do I fix ink absorber is full error message
Good luck. Canon is not help. I have cleaned these and the reset that you can only get online through a third party usually do not work and Canon will not give these out. Basically it is a throw away item. Messy trying to clean them only to not being able to reset the error.
8/2/2014 12:34:28 PM • Canon Pixma... • Answered on Aug 02, 2014
Canon Pixma iP4500 InkJet Printer Logo
436 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
printer sends blank pages
  • Office Equipment & Supplies
