20 Most Recent
ASUS Eee PC 701 Notebook Questions & Answers
2eyb6erd er6r
The number 2 is showing up on your keyboard because you have the Num Lk (Number Lock) key on and you are probably hitting the FN key then the K key so the little number 2 that is on the K key appears as what is typed. for example: On my keyboard there is a Big Letter K key and also on that key is a small number 2 which is blue. In order for me to get the number 2 when I type I have to have the Num Lk key on and then I have to Press and Hold the blue FN function key on the lower left of my keyboard then hit the K key and the number 2 is what gets typed.
Asus 701 sd will not connect to internet
If you have a wireless connection- disable the Router firewall and also your antivirus product firewall and try connecting to the internet.Goto command prompt ( Press the windows logo button and the R button together)Type cmd and hit enterOn the cmd window type ipconfig /flushdns and hit enterThen type netsh winsock reset and hit enterThen restart your computer and check.If you need online technical support, you may very well contact TheBestPcDoctor. I get my all issues fixed by them and it is a reliable support according to my experience. If you want you can also get in touch with them @www.thebestpcdoctor.com or via 877-407-9229
How do I clear cookies on Firefox
Firefox
- From the History menu, select Clear Recent History. ...
- From the Time range to clear: drop-down menu, select the desired range; to clear your entire cache, select Everything.
- Next to "Details", click the down arrow to choose which elements of the history to clear; to clear your entire cache, select all items.
More items...
https://kb.iu.edu/d/ahic
How do I clear cookies on windows xp?
go into your internet page and look for the word tools at the top of your page,click on it and at the bottom you will see internet options,go in there and you will see a page saying,,browsing history,then you will see a box that says,,delete browsing history,tick that box and the click delete.
I turned off auto login and didn't set a password
Remove/reset lost Windows password you can use
Windows Password Rescuer, it can reset/remove Windows 7/vista/xp/2008/2003/2000 password instantly.
I highly recommend [
Daos Password Recovery Bundle 2012].[Daos Password Recovery Bundle 2012] is an all-in-one password recovery software, which recover password for Windows, Excel, Word, Access, PowerPoint, Outlook, RAR/WinRAR, ZIP/WinZIP, PDF etc. Over 70+ types of passwords can be recovered instantly.
I forgot the password to my 701sd eee pc please
Sometimes the only user who has Administrator previliges is the Administrator, this being said did you know that you should try creating another Administrator account and simply delete the old one,. It will at first seem that you did not do anything because you will still see the other administrator until you attempt your save and restart...then presto you should be good. This worked for me on a tower but if it's xp or vista you should be good..hope it helps!!
Password fogotten
If you are using windows you can press ctrl + alt + delete
twice at the login screen and it will give a login screen that looks a little different. Type in the username box administrator
and leave the password blank and hit ok/login.
This should get you to the point when you can then change your password, if you get in and change change your password post back and I will gladly assist you with doing that.
