20 Most Recent Dell Inspiron 1525 Laptop Questions & Answers
simple.just open my computer.there it shows ur drives,documents...down 1 option [web camera] or something like that.open that.and its done.and still if u dont get it,then go to start,settings,control panel.cameras options.open and install the software.then it'l help u.
Dell Inspiron... | Answered on Oct 05, 2019
Did you try booting your computer in Safe mode to check if you receive this error message?
1. Use F8 while restarting the computer.
2. Under Windows Advanced Boot Options select Safe mode and hit Enter.
Check if you receive this error message in Safe mode.
It seems like your drive might be corrupted. If your computer is still under warranty, I would suggest you to contact them to get a replacement. But before you contact them, let us see whether Check disk utility would make a way to boot windows succesfully or not.
If you've Windows Vista Operating System disc, then try running the check disk utility from Windows Recovery Environment.
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type the following command and press enter.
Chkdsk /r
Once your machine has finished repairing the hard drive, type EXIT and press ENTER to restart your laptop.
You can also try typing the following command if Check disk fails to fix the issue. At the same command prompt, type fixboot and press enter.
For your information: If you've a Dell Laptop, then according to Dell, the error code 2000-0142 is a Drive Self Test failed error code. Visit the link below:http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=14B3819735D6B40EE0401E0A55177ED2&doclang=en#HDD
hope 2 help
http://www.bostonrecycling.net/
Dell Inspiron... | Answered on Feb 20, 2019
im doing post this year , not answered, back to jan1,
if fails when dropped and drowned. wow, that is some test , LOL>
At least not shot from a cannon, no?
get it repaired, pops to mind.
foxconn, what is that?ok the mobo maker is that.
is not this PC a relic of 20 years ago?
why mess with relics, no parts for them. hdd yes. battery yes.
the keyboard ribbon connector is not connected
so plug it back in, if the jack is damage, put the PC in the trash.
easy no?
no need to buy expensive parts to fix a $5 not working used PC.'no?
what I do is carbon date PCs then see if last sold for price
last one was $14 whole whopping bucks, or 1buck at the typ, garage sale, H3LL even free. like you.
laptops are like DOG years, and this one is 70 years old.
2008 made, not too old but is dog. based on values now.
the problem with PC is not being able to run w10-64,
if it can't than it has no future. IMO, after all Viruses stink. so....
w10 is the answer. 64bit is best. 32bit is END OF LIFE products.
read page 27 here, at dell, real dell not fake not spam, real.
http://downloads.dell.com/manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1525_service%20manual_en-us.pdf
shows how to replace a keyboard ,just like all service manuals show. wort salt and not from china.
Dell Inspiron... | Answered on Jun 02, 2018
First, check to see there is no physical damage around the charging port, then if you have a AVO meter, check that the charging cord is actually putting out a current; then go to the BIOS and look inside. if you see
Adapter , Unknown device installed, that is your answer - it isn't a Dell charger. Now go to https://www.dell.com/community/General/Dell-Inspiron-1525-new-battery-not-charging-in-BIOS-showing/m-p/4709466
If that message is not there
1. Ensure that the battery is securely in the laptop and that none of the pins on the computer or battery are dirty.
2. Consider that there was nothing wrong with the old battery but the circuit on the motherboard that controls the charging is faulty - there is usually one chip that is at fault in this case.
3. The new battery is completely discharged: does the battery show signs of life when used without the charging cable? If it does, this is not the problem
Dell Inspiron... | Answered on Feb 01, 2018
On the right-hand side near the cd rom drive, there is a switch that moves back and forth. move it towards the back of the computer. that should turn on your wireless capabilities. A wi-fi manager screen should pop and and you should be good to go.
Dell Inspiron... | Answered on Jan 29, 2018
This error message means :-
403 - Forbidden - You can't access the page. You may not have access (it may require a password), or it may be blocked from your domain.
or your Internet site parent controlled site blocker.
Dell Inspiron... | Answered on Sep 22, 2017
You have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Dell Inspiron... | Answered on Jul 28, 2017
Could be an issue with the router. Try resetting the router.
Dell Inspiron... | Answered on Mar 08, 2017
This popup is a sign of a malware infection on your system. You can use ctrl+alt+ del to bring up the task manager, open the processes tab, and locate the pc.exe and agent.exe processes. Select them, right click and end process for each. That should temporarily get rid of the popup. (See link here, and here, but please don't follow the instructions given there to delete files, etc. Just kill the processes and use the following tools.)
Now you'll need to do some cleanup to remove the offending program from your system before you reboot.
Go to this link and follow the first 4 steps of the malware removal guide. Make sure to update MBAM before you scan, and make sure you follow through all 4 steps before restarting your computer. If you want detailed info on how to run the MBAM, as well as a good description of how you got this virus, click here. Then restart your system and see how it runs. I'd advise an indepth scan with your antivirus program to check for further problems, but that should take care of the privacy center rogue.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Dell Inspiron... | Answered on Dec 27, 2016
simply go to device manager and look for the touch pad or mice and any pointing device . click the touch pad look for driver at the top and roll back driver. and if its not working look for the update driver and click that
Dell Inspiron... | Answered on Sep 29, 2016
Did you validate it? Did you actually buy Windows? If you have a certificate of authenticity (with the activation code) and it doesn't work after validating with this code, call Microsoft.
Dell Inspiron... | Answered on Jul 25, 2016
Make sure that the wireless router mode is the same as your laptops wifi adapter.
Older routers are using b/g network modes. Newer router are b/g/n. Check what your laptop's adapter mode is.
Dell Inspiron... | Answered on Mar 25, 2016
Sometimes the brightness is on the arrow keys hit the Fn or function key and press down on the arrow to dim the light or press up on the arrow key to increase brightness
Dell Inspiron... | Answered on Jan 11, 2016
You can't upgrade for no $. But you could (month ago) sign up for Windows Upgrade Offer to upgrade from Windows 7 to Windows 8 Pro for just $14.99, now it is $39.99 and it's no longer the upgrade offer.
If you want to get Windows 8 for free*, that is considered as a crime and piracy, so please do not try to do that.
Dell Inspiron... | Answered on Oct 09, 2015
Make sure your password and addresses are correct
Dell Inspiron... | Answered on Jul 29, 2015
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Dell Inspiron... | Answered on Jun 16, 2015
That is right. Not only you need a password, to open the PC and be able to run the programm's, the password is also a key for encription of the data. No password, no data.
When you do a reset, and install Windows again, you will lose all data on the computer. So is you really can't remember the password and you did not make a mistake with the caps, you should be lost.
I know there are some less legal program's around, but I can't tell you what programs and I even don't know a name. I think you better use Google, to find out which program's are available and how to get them. Perhaps via news groups. But be aware program's to hack a password, come from a certain community. When you have a program, didconnect the computer from the net, try to recover the password and backup the data unscrambled. Then run a good virus scanner and delete the program.
Just saying.
Dell Inspiron... | Answered on Apr 22, 2015
Dell Inspiron 1525 Laptop Logo
979 questions posted
Ekse
Thomas F. Schneider
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
inspiron 1525 function keys
  • Computers & Internet
