20 Most Recent ASUS Eee PC 900 PC Notebook Questions & Answers
Before, I can send and receive files using the
Hello Mylenejavier, To Send and Receive file using Bluetooth requires the following considerations:Make sure your Bluetooth drivers and adapters for your Notebook are up to date.Make sure the device driver of your phone is installed in your Notebook.Make sure that the Bluetooth function on your Notebook is switched on properly.If these steps are not work for you, dial my toll-free number +1 (833) 493-0111 . I'll Surely help you.Cheers,John
9/12/2017 12:28:55 PM • ASUS Eee PC 900 ... • Answered on Sep 12, 2017
My asus eee pc 900 does not turn on.if i press the
You probably put the battery in backwards/upside down maybe?
8/2/2017 6:13:24 PM • ASUS Eee PC 900 ... • Answered on Aug 02, 2017
0answers
Beste,
Be the first to answer 6/4/2017 9:36:03 AM • ASUS Eee PC 900 ... • Posted on Jun 04, 2017Be the first to answer
7answers
Product and activation key wondows 7 ultimate
those come only from msoft after purchase not fixya
5/5/2016 12:45:44 AM • ASUS Eee PC 900 ... • Answered on May 05, 2016
Does Eee PC 900 has an on-screen keyboard?
Windows should have the feature. Check Start menu, Accessibility, or something along those lines. Otherwise it may be in Control Panel, do a search for accessibility.
7/3/2014 3:52:14 PM • ASUS Eee PC 900 ... • Answered on Jul 03, 2014
Changed password on my Asus laptop and now I am denied entry
go to your guest account. open cmd and type net user user_name new_password thats all. The things with an underscore (_) do you have to fill in yourself... Suc6
4/24/2014 7:03:04 AM • ASUS Eee PC 900 ... • Answered on Apr 24, 2014
0answers
Issue with VOIP CAlling
well if the headphone doesnt work the person on the othetr line cant hear you try anothr headphone and see if it works also see if it compatible cause it might be eathr or
3/13/2014 5:21:04 PM • ASUS Eee PC 900 ... • Answered on Mar 13, 2014
7answers
Asus computer password reset.
To unlock a forgotten Windows password on Asus, there are several free methods:1. With another admin account.2. With Windows password reset disk.3. From Safe Mode.4. With CMD.5. Using "lusrmgr.msc"More details you can found on other sites, it is easy to find.Another tip: Unlock forgotten Windows password with Windows Password Recovery Tool.1. Install this program on another computer and create a password recovery disk with USB2. Insert the disk to your laptop and set your laptop to boot from it.3. All user accounts will be loaded, then you can reset any user password.
1/8/2014 9:51:09 AM • ASUS Eee PC 900 ... • Answered on Jan 08, 2014
Eee pc 90ha mb pantalla negra no enciende
Tengo un pc eee top et1602 y la pantalla no enciende se queda negra los led si prende el ventilador tambien ando preocupado si alguien tiene repuesta a este problema por favor enviarme un correo [email protected] o por aca
1/11/2013 8:13:22 PM • ASUS Eee PC 900 ... • Answered on Jan 11, 2013
2answers
My computer speakers are in my computer. They are
Hello there!
That could be a problem with your outdated sound drivers check that.
Please rate my answer! =)
Sincerelly
Aleksandar Adzic
1/8/2013 5:22:55 AM • ASUS Eee PC 900 ... • Answered on Jan 08, 2013
Forgot my email password and cant delete account
Which email account ? Hotmail have a forgotten password link but you must have another email adress to send your forgotten password to just open up another email acc at hotmail.com eg: [email protected] in the right hand corner on the hotmail homepage you should see help center down in the bottom right hand corner tab click on that another page will open you should see another help center click on that again another page will open with account calendar contacts essentials Click on the account tab another page will open with if you have forgotten your password or are having trouble signing in yet another page will open get help with your password problem or signing in click on it you should see something like I forgot my password or I know my password but am having trouble signing in I think someone else is using my Hotmail account at the sign in for your hotmail account click on forgot password tab another page will open then on the reset password tab Hope this helps.
1/6/2013 5:10:12 PM • ASUS Eee PC 900 ... • Answered on Jan 06, 2013
Need to reinstall Windows XP on my Eee 900HA
Bill,If you havent just replaced your hard drive or formatted it, try restoring from the restore partition. I have a newer ASUS netbook, so yours i believe should restore by rebooting the laptop and repeatedly pressing the F9 key. Do not hold down the F9 key, just keep tapping it when it starts up.Follow prompts to restore your laptop to its original configuration when you first purchased it. Make sure to back up all your data, as it will be lost along with all programs and updates that have been installed since day 1.If you have replaced the laptop or formatted it, then youll need to either attach a USB CD/DVD ROM drive or use a USB Flash drive. That method is much more involved, but can be done as long as you have a copy of a Windows XP CD. I’m happy to assist further over the phone at https://www.6ya.com/expert/larry_0800578514b4ccdb
12/26/2012 4:38:30 PM • ASUS Eee PC 900 ... • Answered on Dec 26, 2012
I have an ASUS Eee PC 900. It was working fine
One more thing you could try is taking the battery out for a minute or two, because the Eee uses the atom it has a fairly complex onboard power controller that can overclock / underclock the cpu. Sometimes this gets malfunctions and locks the PC up, the quickest way to fix it is to simply pull the battery for a short while and stick it back in. You may well have already tried this, but it'll be the first port of call.
10/8/2012 12:43:36 PM • ASUS Eee PC 900 ... • Answered on Oct 08, 2012
MISSING AUDIO DRIVER
google the serial model number of your sound card or get it from the asus support center
10/4/2012 10:35:04 AM • ASUS Eee PC 900 ... • Answered on Oct 04, 2012
Asus pc Eee cant connect to the net
have you connect it with a network with your wireless? and does that connection connected succesfully?or are you using modem? does the modem connected succesfully?The url you try to go is valid,i've tried itcomment if you need more information
8/24/2012 6:26:43 AM • ASUS Eee PC 900 ... • Answered on Aug 24, 2012
ASUS Eee PC 900  PC Notebook Logo
308 questions posted
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Eee ASUS
  • Eee ASUS
Most Popular Question
asus computer password reset
  • Computers & Internet
