20 Most Recent
HP Compaq 6510b PC Notebook Questions & Answers
When pluged up it say plunged in not charging
It could be that the battery is at it's full charge. Do you have the correct power adapter plugged into the laptop? Is the battery older than 2.5 to 3 years? Deplete the battery by unplugging the power adapter and letting the laptop use up the battery and shutdown. Then plug the adapter back in and power up the laptop. Does it say charging now?
How can i hook a second battery up?
If there isn't a battery slot then this is not possible.You can carry a spare battery that is fully charged and the swap out the battery when the other one runs flat.If you use your laptop in a car that has a 12volt cigarette outlet then you can purchase a laptop power adapter that plugs into this cigarette outlet to provide power to your laptop.
Battery problem
Your Battery is basically dead. They only have a useful life then have to be replaced. Yours is at the end of it's useful life.
6510b remove keyboard
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01074449
