20 Most Recent Symbol Motorola MC9090 Mobile Computer Questions & Answers
HTTPS is secure but not every website has an SSL certificate and if you try to visit a site over SSL that doesn't have a certificate you'll either get a 404 or a big fat warning
Symbol Motorola... | Answered 2 days ago
enable radio not find wlan
Symbol Motorola... | Answered on Mar 10, 2017
Hi
Contact Motorola Solutions Get Support or Zebra Technologies
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Motorola Mobility Support
That will probably only be adjusted in the actual barcode software that you are using within the mc9090 .. at the moment I am hundreds of miles away from my 9090..but if you still have not resolved this problem. Check to see what the name of the software thats actually turning on to decode the barcodes. It should have a setting...or let me know the name of the software and I'll do some research. I'm not an expert, but have fought with my 9090 for years. I've actually reached its data capabilities and have it sitting on the shelf as relic now
Symbol Motorola... | Answered on Nov 05, 2016
If it is a Windows Mobile 5 device, reload the OS in full using SD card method. If the device is Windows CE5, you can enter IPL mode by doing a coldboot, and whilst inserting the battery back in the device, press the trigger and put it in the cradle until it enters IPL. Once there, you can either use SD card with the OS Hex files or you can use USB Download from Motorola to download the files sing a cradle from your PC. It will be recognised by the PC as this method does not use Active sync.
Symbol Motorola... | Answered on May 03, 2015
Wireless Local Area Networks (WLANs) allow mobile computers to communicate wirelessly and send captured data to a host device in real time. Before using the mobile computer on a WLAN, the facility must be set up with the required hardware to run the wireless LAN and the mobile computer must be configured. Refer to the documentation provided with the access points (APs) for instructions on setting up the hardware. To configure the mobile computer, a set of wireless applications provide the tools to configure and test the wireless radio in the mobile computer. The Wireless Application menu on the task tray provides the following wireless applications: • Wireless Status • Wireless Diagnostics • Find WLANs • Manage Profiles • Options • Enable/Disable Radio • Log On/Off Tap the Signal Strength icon to display the Wireless Applications menu
pg 1-13,
Download manual
Symbol Motorola... | Answered on Apr 07, 2015
Constance
Contact Motorola Solutions Get Support or Zebra TechnologiesSupport Downloads for assistance.
Mark
Symbol Motorola... | Answered on Feb 01, 2015
Peter
Mark
Symbol Motorola... | Answered on Jan 19, 2015
Usually, 95% of the times, hardware error. Will need a new scan engine.
Symbol Motorola... | Answered on Jul 14, 2014
https://motorola-global-portal.custhelp.com
Symbol Motorola... | Answered on Jun 23, 2014
You have a virus.....download and run " USB SHOW" program
Try free downloading at cnet downloading or download.com
When you download the program scan your memory and delete all the unknowed files with del+shift keys twice
Symbol Motorola... | Answered on Jun 19, 2014
Hope this answers your question. First go to the .EXE file you want to be on the desktop. Touch and hold to pull open the sub-menu of that app. Select "Copy". Now go to the desktop. Find an empty section. Touch and hold down to open the sub-menu. Now select "Paste Shortcut". This will put a shortcut on the desktop for you. It will show the word "Shortcut" at the beginning of the title now, which is kind of a pain. A simple "Rename" can fix that though. That should do it!
Symbol Motorola... | Answered on Apr 17, 2014
If using Wavelink, you can type it by pressing SHIFT, Blue Key, N
Symbol Motorola... | Answered on Feb 25, 2014
have you been able to configure a WiFi profile using the on board utility?
If not and if you don't have the icon at the bottom right of the screen you will be able to find it in the windows folder.
If you have a profile setup, does it have a yellow ! icon on it if so, use the icon on the bottom right then> options > Regulatory in the drop down menu > and untick 'Enable...' box
If you have DHCP setup in the profile you may not be getting an IP address, you can check this in the status option from the pop up menu (bottom right).
if you are not getting an IP Address, check all your settings in your WiFi profile.
I normally start with a un-encrypted network to test the unit, then add encryption after you get it all working. You will need admin rights for the AP you are using.
Additionally i have found that some units don't like TKIP type networks with out a software update.
Hope this lot helps.
Symbol Motorola... | Answered on Nov 06, 2013
Symbol Motorola MC9090 Mobile Computer Logo
45 questions posted
Popular Products
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Symbol Computers & Internet
Most Popular Question
got motorola mc9090 when scan barcode
  • Computers & Internet
