20 Most Recent
SMC 802.11a/b/g Wireless Access Point Questions & Answers
MBP8,1 late 2011 new battery not working
You realize people reading this have no idea what this mumbo-jumbo means. Brett has no idea and he is the master of all masters in lateral thinking!
'make model (what it is)', plus a detailed description of the issue!
Wat is the smc networks use for
SMC Networks serves up networking equipment, with or without wires. The company makes wireless local area network (LAN) devices designed for use in homes and businesses.
How to solve USB device not recognized ?
different USB port. There are usually 3 or 4 of them. If you can, format the USB drive (if you have nothing on it or already have copies of what is on it). It will take 10 seconds, but will wipe all data. It should be recognized then.
When trying to use the
look for a windows xp driver file on the included program compact disc that may need to be installed before you use the included program.
Why does my wireless goes down?
Hi,efault
U need to isolate the problem first.
Check if the wireless drops on all devices or only on one particular device.
If it occurs on only one particular device,the problem is with the wireless adapter of that advice..
If it happens on all the devices then the problem is with wireless router
For that
Check for the wireless interference . Avoid having cordless phone base near the router.
Also try changing the wireless channel of the router To 1,6,11
U can do this by logging on to the router set up page of your router
To Find the address of your router,type ipconfig /all in the command prompt.Look for the Default gateway address and type it in the address bar.U will find your Router set up page..and u can change the wireless channel there
