20 Most Recent Peavey Pv 2600 Power Amplifier Questions & Answers
It's on the rear panel - between the power cord and the on-off power switch.
Peavey Pv 2600... | Answered on Dec 26, 2018
Go to http://peavey.com/support/searchmanuals/archived.cfm Their main site also has info. DDT is an active compression feature to protect the product .
Peavey Pv 2600... | Answered on Mar 08, 2016
shop time
Peavey Pv 2600... | Answered on Feb 18, 2016
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Peavey Pv 2600... | Answered on Jan 20, 2015
IS that a 2SD1915 or something else, it looks like an 2SA1022 or NTE2407crosses - Newark Electronics or Mouser might be able to provide you a different cross reference. There are data sheets that seem to indicate a A1022 / NTE 2407 - this one can be found here http://www.mouser.com/Search/Refine.aspx?Keyword=2SA1022 Amplifier Transistor - these are common I think for older amplifiers. If memory serves me right - I probably have a couple old ones I bought to fix a Reel to Reel .
Peavey Pv 2600... | Answered on Nov 17, 2014
is the amp working, maybe the diode is out...maybe the connection to the diode is broken...
Peavey Pv 2600... | Answered on Sep 20, 2014
are you using the 1/4 in jacks or the balanced inputs.
This will depend on your Subs. If they have an inbuilt crossover there will be input and outputs on the rear, with the output marked something like 'tops' or 'Output to HF'
If you have these then it should be a simple matter of connecting yout amp to the subs and then the mains to the output.
If you haven't got a crossover in the subs then you will either need to buy a pair of two way crossovers for the right power and frequency and have these in the speaker wiring or use the amp's inbuilt crossover and run one channel for tops and the other for subs. You will lose stereo but the amp will happily drive a 2ohm load so you should still be able to use all four speakers.
Peavey Pv 2600... | Answered on Feb 09, 2014
As a starting point clean ALL switches on the back of your amp, including the Stereo/Bridge switch then re-check functionality, good luck.
Peavey Pv 2600... | Answered on Nov 07, 2013
It should be able to do this. You would need to put each type speaker on a seperate side and then use either an elctronic crossover or an EQ set to pass only lows into the side for the subwoofer to block sending highs to the subs.
Go to Peavey's website
http://www.peavey.com
You may find what you are looking for here if not you may have to call them.
Peavey Pv 2600... | Answered on Nov 06, 2013
Clean all back switches first of all, use a cleaning solution spray and give a 3 shot per switch, then push in-n-out several times each one and check amp functionality again.
Peavey Pv 2600... | Answered on Nov 05, 2013
Please be advice that the center output connector is only for BRIDGE mode operation, you should not use that way, try to clean all the back switches with a cleaning solution spray, clean all switches and check amp functionality again in stereo mode.
Here is the service manual, scroll down and clic "Get Manual"
http://elektrotanya.com/peavey_pv-8.5c_sch.pdf/download.html
Hope this helps.
Please add more background, which channel stop working?
As a blind advice, try to clean ALL back switches, including Stereo/Bridge Switch, let me know your results.
Peavey Pv 2600 Power Amplifier Logo
97 questions posted
Top Peavey Music Experts
Michial Gueffroy
PNiss
Are you a Peavey Music Expert? Answer questions, earn points and help others
View Most Popular
Peavey Music
  • Peavey Music
Most Popular Question
ddt light one channel stays
  • Music
