wiring is different and you will probably short out something. this is 120 volts and you could get a shock! leave this to a professional. other wise the only thing i would tell you is compare the electrical schematics from both ice makers to varify power and control wiring.
There's no ice
If your ice maker has stopped producing ice completely, check these, in this order:
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
If your ice maker has a small red plastic lever, lower it to lower the wire.
If there's no plastic lever, simply lower the wire.
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes
If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
The water-inlet valve. Replace it if it has failed.
Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
The ice maker mold thermostat. Make sure that it's cycling properly.
Specks in the cubes
If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Did you clean the surfaces thoroughly and glue it down with white or clear silicone, then leave it to cure? also was it an OEM replacement or an Amazon special as the quality is different.
It is called short cycling. Help below
If your refrigerator is short cycling, it can be caused by a number of issues including: An incorrectly set thermostat inside your refrigerator. Dirt and dust on the coils that prevents efficient operation. Faulty capacitors or relays that prevent the compressor from staying on.
Apr 14, 2019
JustAnswerhttps://www.justanswer.com > Appliance Repair
Sep 30, 2014 - i have a frigidaire freezer and its short cycling, it runs about 6 to 10 minutes and then cuts off. what can be the problem and how can we fix ...
1 answer · Top answer: OK so there are only 2 things that can cause this issue---either the defrost timer or the thermostat ...
Diane - Sorry I don't have a Frigidare but check out this site - I have heard of this but your error code could actually be 5b which is the best that they can do to show a Sabbath Day setting that the frig is designed with
Check and scroll down this website to get the description way down on the webpage:
https://removeandreplace.com/2015/08/12/frigidaire-refrigerator-error-codes/
Depends on model. Generic advice in the link and videos. You can effect a power reset by pulling that wall plug for 30 minutes.
Sabbath Mode is turned ON and OFF by pressing
and holding both the freezer "? Down" and refrigerator "? Up"
indicators for five (5) seconds. The display shows "Sb"
while in Sabbath mode
https://www.google.com/search?q=how+to+turn+off+sabbath+mode+on+frigidaire+refrigerator
The E6 error code on a Frigidaire wine fridge, specifically the model FGWC5233TS, indicates a fault with the upper temperature sensor. When this error code is displayed, it means that the temperature sensor located in the upper portion of the wine fridge is not functioning properly or is experiencing a malfunction.
To troubleshoot and resolve the E6 error code, you can try the following steps:
Unplug the wine fridge from the power source for a few minutes and then plug it back in. This may reset the error code and resolve any temporary issues.
Ensure that the wine fridge is properly leveled. Uneven positioning can affect the performance of the temperature sensor. Adjust the feet or placement of the unit to ensure it is level.
Check for any obstructions or blockages around the upper temperature sensor. Make sure there are no items blocking the sensor or disrupting its operation.
If the error persists, it is recommended to contact Frigidaire customer support or a qualified appliance technician for further assistance. They can provide specific guidance based on the model and help diagnose and repair the issue with the upper temperature sensor.
limited information ---unable to give an answer --since you need to test the unit most likely problems overheated/failing compressor [dirty/restricted air flow condenser area --condenser-evap fan fail /short--circuit short ---------breaker failing [but if tripping and resets normal usually not the case ]
Question edited for clarity.
It sounds like the compressor is struggling / overheating / failing. When was the last time your stripped the back out and removed all the fluff and debris? It overworks the compressor and gets red hot when the condenser coils get blocked. The struggling compressor causes the humming. Turn it off, keep the doors closed and vacuum it all out. Clean underneath and you might as well clean the floor and walls around it as the plan is to leave it disconnected for 1 to 2 hours to cool down and settle the refrigerant gas/liquid. Some other ideas below.
The evaporator fan motor circulates air over the coils to help keep things cool inside your fridge. If this motor starts to go bad, it will make a buzzing sound as it struggles to circulate air. You'll need to replace the evaporator fan motor to fix this problem.
Aug 22, 2022
