20 Most Recent Casio CTK810 61 Key Keyboard Questions & Answers
You can't use SDCARD for CTK810 model.
Please connect to a computer using a USB cable. Then you can use a commercial MIDI file player to play to your keyboard.
Alternatively, you can download SMF Converter from
http://music.casio.com/e/smf/
This program will convert SMF (.mid files) into a format readable by your Casio keyboard and then load it directly into your keyboard.
Casio CTK810 61... | Answered on Jul 25, 2016
If you connect to PC using USB interface, then use a commercial midi player - e.g Melody Assistant or Harmony assistant to play MIDI files to it.
Or else download "SMF convertor" to convert midi files and download compatible file to keyboard.
Casio CTK810 61... | Answered on Sep 18, 2015
You can use TRANSPOSE/SETTING button.
Each press the TRANSPOSE/SETTING button cycles through the setting screens. If you accidentally pass the screen you want to use,keep pressing the TRANSPOSE/SETTING button untill the screen appears again.
To lower by one octave,set the value to -12
You also can use PIANO SETTING button.
Find the setting in page 07 of PIANO SETTING.
Casio CTK810 61... | Answered on Sep 03, 2015
you can run 32 biut software in win7 64 bit. something else is the problem.
Casio CTK810 61... | Answered on Feb 16, 2015
64 bits and 32bits drivers for Win 7 & 8 have been made available at
http://support.casio.com/en/support/download.php?cid=008&pid=20
You must first load the driver first by running dpinstal.exe BEFORE you connect the USB cable when program tells you to do so.
Casio CTK810 61... | Answered on Aug 22, 2014
Windows 8,7,Vista, XP - both 32 bits and 64 bits available
Casio CTK810 61... | Answered on Aug 12, 2014
Both 32bit and 64 bits drivers for Win 7 & Win 8 have been made available at
Casio CTK810 61... | Answered on Aug 11, 2014
Defaults to funtion for a sustain pedal. May be reassigned as Soft, Sosonato
sostenuto pedal or even a footswitch to start the accompaniment.
Casio CTK810 61... | Answered on Aug 03, 2014
You need to get latest USB driver for Windows 7 (both 32bits and 64 bits available) at:
I think the SMF converter though is a 32 bits application will work on windows 7 provided the correct USB driver has been installed.
Buy a USB A to B cable (as used for printers)
Download latest drivers for PCs (sorry no Macs) from:
Casio CTK810 61... | Answered on Aug 02, 2014
yes but your have to buy the disk. from pro tool to make it work. you cannot use the simple protool be cause it give you 15 day to use it and than it will expire. and plus your not going to get all of the conponet from try verison.
Casio CTK810 61... | Answered on Jun 24, 2014
Yes. New drivers are NOW available on the Casio website.
Casio CTK810 61... | Answered on Dec 17, 2013
The AC adaptor of my Casio Keyboard has reversed polarity from the Standard Power AV adaptor you get in the market. The center is NEGATIVE. When you try to use a new power supply that is NOT a CASIO original, you may need to reverse the polarity of the plug. Check that.
Casio CTK810 61 Key Keyboard Logo
77 questions posted
Top Casio Music Experts
Michial Gueffroy
Norman  J Weimar Jr
Norman J Weimar Jr
Ekse
Are you a Casio Music Expert? Answer questions, earn points and help others
View Most Popular
Casio Music
  • Casio Music
Most Popular Question
casio cps 50
  • Music
