20 Most Recent Yamaha Electric Guitar Questions & Answers
Santana's had quite a few guitars, take your pick:
1972 - Gibson Les Paul / Gibson SG Special with Humbuckers / Gibson L-6S
1975 - Gibson SG Special with P90 pickup (Woodstock Festival)
1976 - Yamaha SG 175B / Gibson SG Special with 3 Open Coils
1982 - Paul Reed Smith (PRS) Custom
1988 - PRS Santana II with PRS Santana III nickel-plated pickups and .009-.042 D'Addario strings
Yamaha Electric... | Answered on Jul 06, 2019
It was made April 2003
Yamaha Electric... | Answered on Sep 03, 2016
i don't really know what instructions you expected, although you should have received something for the tuner and amp. I suspect that you are new to playing the guitar, as, I don't wish to sound disrespectful, you would know what to do! So first, and again I hope not to sound like I'm treating you like a dummy, plug the guitar into the tuner input. Or if It's a piezo tuner clamp it to your headstock. Most tuners are now automatic so it should pick up on the string you are striking.Repeatedly pluck the same string til the tuner changes colour, or flashes, or some other indication to tell you the string is at pitch. Repeat the above for all 6 strings.
Then plug the cable into the amp input, switch it on, and bugger about with the controls til you get a half decent sound. ( thats what the rest of us do).Don't expext too much from this package, it is budget level, but of quite good overall quality.hope this helps
Yamaha Electric... | Answered on Feb 16, 2015
depends on where you are. You can try
Bass Guitars
Yamaha Electric... | Answered on Feb 03, 2015
does that guitar still has warranty? where did you bought it? try to go to music repair shop and consult it. they will help you bigtime. promise. i hope i helped you even a bit. thanx
Yamaha Electric... | Answered on Feb 02, 2015
If I understand your question correctly, the tuner (the little machine that the string winds around so that you can- yep! you guessed it- tune the string.) has come loose/is coming loose from the guitar. Or someone offered to "fix it" and lost a screw.
Either way, you can do one of two things: look on a website called StewMac.com. the Stewart McDonald company has been doing this since 1968, so they'll probably have the part.
If, however, you want a little faster response: Get your guitar and find a music store that's been around awhile- a long while. Go inside, be careful not to knock anything over (because the light will be dim, and there will be stuff stacked and displayed *everywhere*. Walk to the back of the store (past the tatted salesmen and the harassed-looking girl who's answering the phone) to the repair counter. Ask the guy for the screws that you need- he may recommend that a larger size is needed if the hole has been stripped.
Either way, you'll have the hardware you need- probably for about a buck or two.
Keep playing!
Yamaha Electric... | Answered on Sep 26, 2014
Can you forward some photos to me? Serial numbers and Kay guitars vary by the age of the instrument. Also can you take a photo of any label inside the sound hole or at least tell me what it says in there, where was it made, etc. I'll await your response.
Yamaha Electric... | Answered on Jul 14, 2014
Try taking the guitar back to the store where you got it. Recreate the sound. If it is a faulty connection they will know what to do about it.
Yamaha Electric... | Answered on Jun 17, 2014
Dont give up on the neck. One tec you saw may not know what another that has had many years in the repair of gtrs knows !. But for the time being you can fix this your self. Find a alan wrench that came with your Gtr.thats your ntail pice. This is the bridge that each string cross,s over. Now slowly rase up the height of the string untill its high enough to stop the buzzing. Just half turns at a time. . All so if you keep the humitdy up near your gtr. it may correct its self, no **** just like magic. keep on playing DFD
Yamaha Electric... | Answered on Apr 29, 2014
What type yamaha is this and what type problem? The serial no is irrelevant.
Yamaha Electric... | Answered on Feb 21, 2013
Any standard screw in whammy will work they're the same as a stock Fender Strat.
Good luck, Cody J.
Yamaha Electric... | Answered on Jan 31, 2013
Yamaha Electric Guitar Logo
Popular Tags
77 questions posted
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
View Most Popular
Yamaha Music
  • Yamaha Music
Most Popular Question
serial number cj 818a yamaha acoustic
  • Music
