20 Most Recent Samsung SCH-U470 Juke Cellular Phone Questions & Answers
I have no idea! But you could try google to see if there are any fixes
Samsung SCH-U470... | Answered on Mar 04, 2018
  1. From the main screen, press the centre of the navigation wheel to choose Menu.
  2. Select Settings & Tools then press the centre of the navigation wheel to choose OK.
  3. Select Phone Settings then press the centre of the navigation wheel to choose OK.
  4. Select Security then press the centre of the navigation wheel to choose OK.
  5. Enter the lock code then press the centre of the navigation wheel to choose OK.
    The default lock code is the last 4-digits of the mobile number.
  6. Select Restore Phone then press the centre of the navigation wheel to choose OK.
  7. Select Yes to confirm then press the centre of the navigation wheel to choose OK.
Samsung SCH-U470... | Answered on Aug 09, 2017
I have an SCH-U450 and had the same annoying AA on my nice wallpaper picture.
Although it doesn't appear in the icon library, apparently, it's for Auto Answer. As soon as I turned that off, it went away.
In my phone to to, Menu > Settings & Tools > Call Settings > Answer Options, and make sure Auto w/ Handsfree checkbox is UNchecked (unless, of course, you want it on, in which case, I guess you're stuck with the AA in the middle of your nice wallpaper picture).
As for the audio announcement, mine was set when I got it to yell out the name of the contact for messages and calls. Try Menu > Settings & Tools > Sound Settings > Call Sounds > Call Alert, then choose Ring Only, or others as appropriate.
Samsung SCH-U470... | Answered on Apr 12, 2014
May be the charger is bad. try a new charger. If it works then but it (charger).
Samsung SCH-U470... | Answered on Oct 30, 2013
micromax x511 flight mode.how 2 come out of it.
Samsung SCH-U470... | Answered on Oct 10, 2012
only hard reset can slove this problem
Samsung SCH-U470... | Answered on Aug 29, 2012
only solution----change the handset
Samsung SCH-U470... | Answered on Jun 05, 2012
Hi, You may contact to your service provider Samsung SCH-U470 Unlock Code, they can open up all networks for you where you want to use your phone. Once your phone is unlock, it will work with any networks worldwide without sticking to one network only. I suggest to visit Samsung Unlock Code site, they will provide an accurate code with easy to follow instructions on how to unlock your phone.
Hope it helps.
Thanks.
Samsung SCH-U470... | Answered on May 01, 2012
Hi, I found this site on web, maybe it'll help.http://www.resetcellphone.com/how_to_reset_Samsung_sch-u470-juke
Good luck.
Samsung SCH-U470... | Answered on Apr 26, 2012
  • Power on without SIM
  • From the standby screen, press the “Dial” menu
  • Type in #7465625*638*Unlock code# (8 digit unlock code*)
  • Device should say: “Network Lock Deactivated”
  • The 8 digit code can be obtained by calling AT&T Technical Support and given the representative the IMEI number. In exchange they will give you the Subsidy Unlock Code.
    To obtain the IMEI number press *#06# on your mobile device
    Samsung SCH-U470... | Answered on Apr 07, 2012
    Your cell phone may be locked to a particular cell phoneprovider and in this case it needs to be unlocked to use with a different cellphone service provider.To get the security code/restriction code to unlock the cellphone from the current cell phone provider so you can use the SIM card with adifferent phone provider, Please click on this link and follow my instructions:-http://www.fixya.com/support/r4049238-unlock_cell_phoneIf yourphone provider does not help you then these WEB sites it provides securitycodes for a small price.http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHwhttp://www.mobileunlocksolutions.com/
    Samsung SCH-U470... | Answered on Mar 28, 2012
    Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
    1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
    2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
      View Picture
    3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
    4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
    5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
    Samsung SCH-U470... | Answered on Feb 25, 2012
    i know how to remove sigmatel s90 " high speed sim!"
    Samsung SCH-U470... | Answered on Nov 12, 2011
    Samsung SCH-U470 Juke Cellular Phone Logo
    237 questions posted
    Top Samsung Cell Phones Experts
    Felizardo Erilla
    Felizardo Erilla
    Bill Long
    John Tripp
    John Tripp
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
    View Most Popular
    SCH Samsung
    • SCH Samsung
    Most Popular Question
    getting out from flight mode
    • Cell Phones
