20 Most Recent
Samsung SGH-Z170 Cellular Phone Questions & Answers
How can I join internet servces - airtel
hi that model phone has no wifi .....the only way u can go on internet is to buy a phone with wifi if u get a cheap smart phone it will work .........good luck
Phone is asking for a code an now it is locked
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
I can´t get in my puk code. it asks me for a
sir please call to the related simcard customercare and say the last 6-digit number which is present before the simcard. then they will give the pukcode number to unlock the cellphone...........
My sgh-z170 wont turn on.I asked to repair they
Hello
Yes, the problem is most probability software related. The best and fastest way of resolving this problem will be to take your phone to your nearest service centre let they reload the firmware of the phone. They usually do this free of charge.
Hope this can steer you in the right direction.
Kind regards
Andrea
How can i transfer photo from pc to samsung sgh z-170
Connect the phone to the PC using USB cable, go to MY COMPUTER to access the phone, open the folder where you want to transfer the photos and copy files from you PC to paste in the Folder.
NOTE: This is only easy when you have a memory card in your Phone, else you will need a Samsung PC Suite.
Hope this helps you.
Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
My samsung sgh z170 wont turn on
Did you check the battery ? If it can't be recharged , then that means your battery is dead and you need to replace it .
good luck .
