20 Most Recent
Sony Ericsson W910i Cellular Phone Questions & Answers
I want to use this phone in india purchased in USA
Yes you can use that kind of phone in India. All you have to do to make it operable is to buy a sim card that belongs to India country Telecommunications company which offer services to your phone. Below is the list of India Mobile Service Providers.
Cellular Mobile Telephone Service Providers
- Bharti Cellular Ltd
- Sterling Cellular Ltd
- BPL Mobile Communications Ltd
- Hutchison Max Telecom Ltd
- Modi Telstra Pvt. Ltd
- Usha Martin Telekom Ltd
- RPG Cellular Seravices Ltd
- Skycell Communications Pvt. Ltd
- Airtel Digilink India Ltd
- Fascel Ltd
- Hexacom India Ltd
- JT Mobiles Ltd
- Koshika Telecom Pvt. Ltd
- Tata Communications Pvt. Ltd
- Escotel Mobile Comm. Pvt. Ltd
- Bharti Telenet Ltd
- RPG Cellcom Ltd
- Modicom Network Pvt. Ltd
- Birla AT&T Comm. Ltd
- Reliance Telecom Ltd
- BPL Cellular Ltd
- Srinivas Cellcom Ltd
Source:
India TelecomHope this helps..
Unlock codes
http://www.sonyericsson.com/cws/support/phones/detailed/phonelockcodeissues/w910i?lc=en&cc=nz
or
To change the phone lock code:
- From standby, go to 'Menu' > Settings > General (tab).
- Select Security > Locks > Phone protection.
- Select Change code and follow the instructions.
To activate the phone lock protection:
- Select Protection > On.
Bluetooth problem.
Your phone probably has a lock on it which prevents you from receiving ringtones, games, music, stuff like that from other users
W910i hanging problems
The hanging problem might be as a result of the follow:
- Maybe there is a virus on your phone.
- Maybe the phone memory is full.
- Memory card also might be full or maybe the memory card has virus
- Your phone operating system might me corrupt.
Solution(s):
- Try to delete the files on the phone memory and let's see what happens
- Remove the memory card and put on the phone without it and see if the phone will still hang
- Master reset the phone and see if phone will still hang
If you try all the above and your phone still hangs, then you will have no choice than to take your phone to a qualified phone repair shop for software restore. That is, computer will be used to format your phone and the phone software will be reinstalled afresh to its factory default state and you will not see any trace of hanging on your phone any more.
I wish you the best.
My sony w910i has been
You have dry connections in the phone,maybe caused by water or moist.Only solution is the repair shop.
My phone keys are cracked
If you have insurance on the phone you call them to submit a claim, pay $50.00 and get a refurbished phone. Or you can order replacement keys and replace yourself. My 15 year old son has had this problem and we have fixed it 2 times with parts from his sisters old phone and replacement keys we found on ebay.
How to put new fascias on w910i helllllllllllllp
- Turn off the phone.
- Remove the 4 screw covers on the back of the phone, 2 on the top of the main body and 2 at the top of the slider.
- Take out the 2 screws at the top of the main body.
- There is a 3rd screw on the right hand side of the phone above battery pack, take this out. dont forget where each screw came from.
- you can now remove the back plate.
- next you will need to remove the 2 screws on the top of the slider.
- Remove the battery pack.
- (make sure the slider is OPEN) You will see two screws on either side of where the battery pack was. Remove these.
- You can now Remove the front plate.
Bassically uncrew all the screws. take it apart, put your new stuff on and then do everything again backwards.
Email settings for sonyeric k810i
Menu>Messages>>>Email>>Settings>>New Account>> Add>> Account name>> Connect using>>(Chose your ISP)>>enter email address>>select Connection type as POP3>>incoming server address for the mail you want to configure (ex yahoo= pop.mail.yahoo.com, google: pop.gmail.com) username: (yahoo or gmail login id)..>> Password( for you account)..>> outgoing server (yahoo : smtp.mail.yahoo.com or for gmail: smtp.gmail.com) please specify your login credentials again, then port number is 110 and 25. should work.
Need unlocking code for w910i
If you want unlock code for Sony Ericsson,then i would recommend the site
Prounlocking.com .Here you need to specify Country name and service provider of your phone.Then they provide unlock code with free instructions.This is reliable and secure.
How i got my puk code i loss my sim card
The PUK code is of no use without the SIM card.You need to get a new SIM card from your cell phone provider and the PUK code will be supplied with this new SIM card. Keep the PUK code in a safe place so you can access it when you need it.
