20 Most Recent
Sony Ericsson Z750a Cellular Phone Questions & Answers
Message alert
you have to change your message tone because there is no other option to reminder
Phone fell in coke; Corroded motherboard
coke has acid in it, it's a conductor, you have more problems than a motherboard, such as a bad lcd bad speaker sticky buttons(sucrose). the solution to your stated question assumeing you want to throw away money is to use e-bay and buy a phone with a bad lcd mising buttons or something to that nature basically a bad phone that has everything wrong with it accept the motherboard and bid low.
my advice is because this is an older phone just buy a working one off e-bay or a used phone site, unfortunately tho because this is such a great phone despite it's age, it's in demand, and you'd be lucky to find one for 30 dollars at an avrage of around 50. they go fast
Text message won't send.......Sony Ericsson Z750a
I had a similar problem when dealing with my own phone of the same type. The only permanent solution is to engage the master reset which you can find in the settings folder. A temporay solution is to go to your outbox, and you'll have a message that either has a little red x on it or just is a plain letter shape. if you try to delete this it will say one or more messages can't be deleted. make sure you change it's status to canceled, then select it choose send to drafts. make sure there are no messages in your outbox and only the one message you just moved to drafts in that folder. it still will npot allow you to delete the message. remove your battery while the phone is still on. replace reboot go to drafts and you should be able to then delete the message from drafts. if you still can't the only option i see, which is what i did, is to use the master reset
Cant send text messages any more
hi there,
call the customer service of your service provider ( AT&T,Vodafone,Verizon etc)....they will set up message center number on your phone , the one that you have might be incorrect...your mobile operator will send you sim updates that will refresh the settings ....and then you will get the text message options
cheers
Unlock code for sony Z750A
Contact the carrier that the phone was purchased from. They will need the IMEI to provide you with the correct unlock code.
I forgot the lock code for my sony ericsson z750i
the phone lock code protects your phone against unauthorized use if
it is stolen and the SIM card is exchanged. To be able to switch the
phone on, you need to enter the four-digit phone lock code. The Sony
Ericsson default phone lock code is '0000', but you can change this to
any 4-8-digit personal code. When you buy the phone, the phone lock is
by default turned off. Note: For security reasons, your
operator, retailer or Sony Ericsson Contact Center cannot retrieve the
lock code through the phone or the network. If you forget the code,
locked phones must be sent to a service centre. locked phones must be sent to a service center.
My AT&T Sony Ericsson Z750a is asking for a
your........ ""friend"" has a sim card pin number enabled you can only disable it if you know the pin number.
solution=enter pin number -boot up phone-enter settings and disable
PS: "THEY'LL CATCH YOU ONE DAY."
IF YOU TALK WHILE CROSSING STATE LINES using a stolen sim card IT'S A FEDERAL OFFENSE btw.
My z750 phone well not send text messages
This is something that you need to discuss with service provider. If you are able to see sending icon and ultimately, not able to send, either you need to change SIM MESSAGE CENTER NUMBER which is only to be offered by Service provider. There might be a chance that there might be a glitch from their side . ( I have seen many cases like this ).
Note - I am taking into consideration that the General settings are all fine. Make sure you have not disabled send messages option.
Kindly refer to manual for more general settings details.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
