20 Most Recent
Samsung SGH-a437 Cellular Phone Questions & Answers
How to reset phone password
hello,
to reset the password, go to menu, go to settings, the one with a spanner logo, check for the security, select password, click on phone password, enter the old password, then enter the new password, re enter the new password and it would reset.
How do u take a number off a block list
My Daughter had this very same problem today. She said "Daddy, i can't figure this out" and then after we fooled around with it for a bit she figured it out. Haha.
Here is how you do it:
-Go to menu
-Go to messaging
-Go to messaging settings
-Go to text messages
-Go to block number
-Highlight the number you wish to remove
-Press options
-Press delete
And tada, you've unblocked you're number.
I am conected to handset
bluetooth will be installated ,make sure it will be visible to all .this is done in your settings division
When i saved my picture
If the photo was taken properly it will be saved within the phone. Now open camera and use the left corner key to open the OPTIONS. You will find the links to the previous files and it can be opened. Normally the camera shots go to the image folder and it can be transferred and named into the memory card- my pictures.
Free unlock codes
I was not able to get a free unlock code for the mobile model that you have specified.You can get the unique unlock code for your Samsung SGH-A437 from
Wickedunlock.com and remove the network restriction.You need to specify the country,locked network,IMEI and get the unlock code along with free unlock instructions.
How do i find a lost phone
If your
mobile phone is lost or stolen you can inform your cell phone provider with your IMEI number. Your cell phone provider can then put the serial number on a shared database. This list stops this particular phone from registering on any network and will be useless for anyone even if the mobile phone's
SIM card is changed. It is not possible to trace your cell phone, even if you had setup a tracker program on the phone, it can only give the location of your cell phone in the coverage area where the cell phone transmitter tower is located. Your best bet is to ring your cell phone and hope the person who answers your cell phone will return your phone to you. Otherwise I suggest you contact your cell phone provider ASAP. To lock/block your cell phone from further use, please click on this link :-
http://www.fixya.com/support/r5057854-lost_or_stolen_cell_phone
My samsung gt-c3530 mobile does
As this handset is an old model you need to check the manual for the supported file format, and resolution support. You can check the DNS settings from your service provider.
My samsung phone gt c
this is bcoz image dpi is more than 72 (for me it is 96 ) so convert it to 72 or less it will open even default camera takes image with 72 dpi i converted to 72 dpi using Adobe Photoshop
Sgh-a437 phone locked, is there a factory unlock
You can get the factory unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website
Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
