20 Most Recent
LG KG270 Cellular Phone Questions & Answers
Unlock code for kg270
Dont worry i Can Help you on this .................
don't worry you can unlock your phone
you need unlock code
you can get unlock codes there are number of providers available
but this is some thing special very good service
try this Click here
good luck
7/25/2022 8:45:17 AM •
LG KG270...
Answered
on Jul 25, 2022
Invalid security code
You are going to have to do a factory reset on it. You will lose all the stuff you had
4/1/2017 7:26:13 PM •
LG KG270...
Answered
on Apr 01, 2017
Track lost mobile
You should have installed iKeyMonitor on your cell phone. https://ikeymonitor.com/
9/13/2016 1:20:21 AM •
LG KG270...
Answered
on Sep 13, 2016
I forget my password lg
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
3/11/2012 12:27:37 AM •
LG KG270...
Answered
on Mar 11, 2012
I forgot my lg kj270
you may use this code- 1234
OR
if it doesnot work go to the nearest show room and get them unlock iy
```PLEASE RATE MY ANSWER AS GOOD AS POSSIBLE```
7/3/2011 3:07:11 PM •
LG KG270...
Answered
on Jul 03, 2011
I m using an operator's
It seems that your new operator SIM card doesn't nave coverage at your area, that's why it's showing roaming because the SIM is using (registered) a host network, maybe if you make a manual search of the new SIM operator network, you could register it at its own network, if it's not found, you should report this issue to its customer service.
2/11/2011 11:41:53 PM •
LG KG270...
Answered
on Feb 11, 2011
HOW TO SWITCH ON THE PHONE?
HI,
To switch on the phone please press and hold the end call button for about 4 seconds it wil switch on.
Follow the same procedure for switching off also
For easy understanding i have attached you a image
Thanx
7/28/2010 11:06:55 AM •
LG KG270...
Answered
on Jul 28, 2010
I have a problem with my lg kg270, insert sim
this error message means that your cell phone cannot read or detect the SIM card. Either the phone is faulty or the SIM card is faulty. You need to take the phone and SIM card to your phone service provider to check your phone and SIM card.
2/14/2010 3:26:10 AM •
LG KG270...
Answered
on Feb 14, 2010
