20 Most Recent Kodak EASYSHARE M1063 Digital Camera Questions & Answers
hi,
May be your mov file is corrupted; to repair it back, just use file repair software. Few days before, i was also suffering from the same problem. This tool has helped me to repair mov file and i got all my precious videos back. Try this, it will surely give you positive result.
Kodak EASYSHARE... | Answered on Nov 05, 2019
What u need is a video converter.
Try Pavtube Video Converter(http://www.pavtube.com/video_converter/)
It can convert mov to avi without quality loss.
easy to use, reasonable conversion speed.
Kodak EASYSHARE... | Answered on Sep 17, 2019
What model Kodak 8.0 megapixel camera? The M1063 is a 10 megapixel model.
Some Kodak cameras can charge the battery when you connect the camera to a power source. Some Kodak cameras come with a separate battery charger. Some Kodak cameras use disposable batteries. Without knowing the model of your camera I can't tell you how to charge your camera.
Kodak EASYSHARE... | Answered on Dec 23, 2016
Memory battery present?? (coin type)
Kodak EASYSHARE... | Answered on Mar 15, 2016
Either an error occurred during charging, an AC power disruption occurred during charging, the wrong AC power adapter is being used, batteries are over- discharged, batteries are defective, or no batteries are installed in the camera.
Try charging the batteries a couple of times. If that fails, try charging the batteries in an external charger. If the batteries still will not charge, purchase new batteries and try again
Kodak EASYSHARE... | Answered on Feb 20, 2016
The camera has a battery level indicator in the bottom right hand corner of the LCD display.
Kodak EASYSHARE... | Answered on Apr 28, 2015
You may be able to adjust the screen brightness. If that doesn't help, then shading the screen is your only option. I gave up on my Kodak camera. . .
Kodak EASYSHARE... | Answered on Apr 16, 2015
Look under settings and turn up the brightness. Being a camera it probably has no way of adjusting to the bright light outdoors. I think only newer "sports" models would even be able to do so. Crank it to maximum. It still may be hard to see.
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Kodak EASYSHARE... | Answered on Nov 22, 2014
There is an internal battery in most cameras that is charged by the Lithium Ion battery when the camera is in use. If the camera is being used and the Lithium Ion battery is fully charged and yet the time/date is not being stored then there is probably a problem with the internal battery
Kodak EASYSHARE... | Answered on Sep 20, 2014
hello, use a card reader, or change the cable
Kodak EASYSHARE... | Answered on Jun 09, 2014
Kodak EASYSHARE M1063 Digital Camera Logo
565 questions posted
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
tell when battery getting low
  • Cameras
