20 Most Recent
Panasonic DMC-TZ5 Digital Camera Questions & Answers
Tz5 draining batery
Please clean the battery contacts in side camera battery compartment. Make sure the connector pin are clean not rusted. After cleaning try a charged new battery and see the result.
8/7/2012 4:43:36 PM •
Panasonic...
Answered
on Aug 07, 2012
This memory card is locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
6/6/2012 4:31:02 PM •
Panasonic...
Answered
on Jun 06, 2012
When I turn the camera
Hi, either the screen cable needs to be reseated in the clamp or the LCD has gone bad due
to water damage or other.
5/28/2012 6:19:24 PM •
Panasonic...
Answered
on May 28, 2012
How to load pictures from my panasonic dmc-tz5 digital camera to my computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
3/30/2012 5:37:04 AM •
Panasonic...
Answered
on Mar 30, 2012
My tz5 takes pictures okay
HI!, IAM FROM BANGALORE, I HAD A LCD PROMBLEM IN MY PANASONIC TZ5 AND I REALLY LOVE MY CAMERA , I GOT MY CAMERA LCD FIXED IN 30 MIN AT PANASONIC SERVICE CENTRE- MATA ELECTRONICS, SP RD ,OPP TO VIVEK COMPLEX,BANGALORE. CONTACT MR VIJAY( SERVICE INCHARGE) 9035871324. THANX
11/25/2011 7:03:08 PM •
Panasonic...
Answered
on Nov 25, 2011
I dropped my camera and the screen is ruined. Can
These are great cameras and easy to repair. You can find a Screen cheapon Ecrater. Just search for LCD DMC-TZ5. I would go with an original screen thathas its backlight attached already and not an aftermarket. Before you repair make sure your lens is still good otherwise you mayalso have to buy a Lens. A hard drop could have damaged your lens also.
10/31/2011 12:00:16 AM •
Panasonic...
Answered
on Oct 31, 2011
Whenever i put the memory
Hello
OK, if the memory card itself is locked, you might
sometimes get this error code. All you need to do is to take out the
memory card and switch the lever on the left side to the unlock.
If
the error is still displayed after you did the above, you might want to
try the card in another camera.
If
the card works in another camera . the problem is with your card reader
in your camera.
If you open you sd slot and look inside with a
sharp light , you should be able to see on the left side of the slot
there is a little copper or spring steel lever switch. This switch work
as follows:
1. When no card is inserted / no write protection ,
the switch is open and thus the protection is off.
2. When locked
card is inserted , the tab is depressed and tells the camera that the
card is lock.
Contrary to popular belief ,the little tab on the
sd card is not an electronic switch and does not physically influence
the card operation itself. If you put a locked card into a camera
without a sd lock switch , you would still be able to use the card
normally.
It is incredible difficult to fix this switch because
of space limitations in the sd card. Look into the sd slot and if you
can see the switch , use a needle to pull the little tab down toward the
base of the camera by about 2mm or until it works being careful not to
bend it.
If this does not resolve your problem , there might be a
short in the switch circuit and the camera will need to be disassembled
to resolve this error. This should cost no more than $50.
Please
feel free to contact me if you need further information
Kind
regards
Andrea
9/22/2011 10:07:05 PM •
Panasonic...
Answered
on Sep 22, 2011
I can't change the language
Set the REC/PLAY switch to record (the camera icon) and turn the mode dial to the camera icon. Press the button at the center of the cursor pad to bring up the menu. Select the wrench icon, then the speech-bubble icon.
8/22/2011 5:12:57 PM •
Panasonic...
Answered
on Aug 22, 2011
