20 Most Recent Samsung L200 Digital Camera Questions & Answers
You can get the manual on the link below so you can learn how to use the camera.
http://downloadcenter.samsung.com/content/UM/200902/20090202155610968/L200_English.pdf
Good Luck
Samsung L200... | Answered on Nov 04, 2019
Here you go.
Buy.com
http://www.buy.com/prod/slb-10a-1050mah-battery-charger-for-samsung-l200-l210-wb550-tl9/q/sellerid/27726616/loc/111/217289838.html
Amazon
http://www.amazon.com/Samsung-Camera-Charger/dp/B001K9SM2I
Samsung L200... | Answered on Oct 29, 2019
You can download the USB driver from Samsung's support website here:
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=SAMSUNG%20L200
The download is compatible with Windows 98 and above. Just click on the downloads tab and driver sub-menu.
Samsung L200... | Answered on Oct 16, 2019
You can recover lost photos from memory card of your digital camera with this
1. Do not save any new photos into the memory card of your camera.
2. Insert the memory card into a card reader. Connect it with computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is Tenorshare Data Recovery (simply because i was using it and it worked)
http://www.any-data-recovery.com/product/datarecoverystandard.htm
4. Install and open the program, select your memory drive, and click 'Start' button to start scanning process which will find your lost photos.
Samsung L200... | Answered on May 13, 2019
Can I use my Samsung L200 Digital Camera As Web Cam?
What de software were needed?
Solve my Problem Plz..............
Samsung L200... | Answered on Feb 19, 2019
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP08&prd_ia_cd=04010400&prd_mdl_cd=&prd_mdl_name=SAMSUNG+L200
the driver I understand it is for an elder version of windows...but the samsung master software works with all...and it probably has a driver inside...
Samsung L200... | Answered on Nov 16, 2018
Unlikey, but just to be sure, head to Settings / Reset to set all the camera settings back to factory default, and see if that solves your problem.
Samsung L200... | Answered on Nov 11, 2017
Low or defective battery.
Samsung L200... | Answered on Jun 01, 2016
Greetings.
To resolve this problem you need to replace the ribbon cable inside the lens shutter.
For the unprepared person, unfamiliar with the repair of cameras - a difficult task. Such work can perform any repair.
For self-repair is necessary:
1 soldering iron, solder, flux
2 Tweezers
3 Screwdriver, small
4 Device for capacitor discharge flash
5 optics for if poor eyesight
Skills:
1 Reading the manual repair
2 The ability to solder
3 understanding of the mechanics of the lens (you must correctly parse and then properly assemble the mechanical part of the lens)
Flex -
Flex Samsung shutter L201 digital camera
Manual -
Samsung Digimax L201
Samsung L200... | Answered on Oct 04, 2014
Hello there,
It sounds like your rechargeble battery is dead.
You will have to buy a replacement battery.
Rechargeable battery Lithium-ion battery (BP70A, 740 mAh)
You will probably get it cheapest on Ebay. Make sure the Ebay picture matches your Battery.
The way to get your Battery out of the Camera is on Page 15 of your user Manual.
If you have not got it, you can download it here
http://downloadcenter.samsung.com/content/UM/201008/20100830102834921/PL200_PL201_English.pdf
Samsung L200... | Answered on Sep 22, 2014
Put the back on with one screw, try it. IF it works put in another screw and try it, do this until you find the problem. If you have screws that are different length, you may have one in the wrong spot.
Samsung L200... | Answered on Aug 23, 2014
Your problem - Zoom not work -
If you want to repair yourself - use this documentation -
L210
Samsung L200... | Answered on Aug 20, 2014
When the camera accesses the memory(card) a green LED will burn or flash. When it can't do what it wants, it will warn you.
A memory error, can be caused by lots of things. Like card full, card physically damaged, file system damaged. Too many folders, too many pictures. Wrong card (SD, SDHC or SDXC) cannot be used in every camera.
Check if you did put in the card correct (not the wrong way around) Check if all contacts on the memory card are clean, shiny and straight. Check if you did not switch the lock switch to the wrong position. Check if there are still pictures on the card, in an external memory card reader. put all the pictures you can find on the computer and than try to format the card. (in the computer, FAT 32) but after you put it in the camera. do a format in the camera too.
Success
Samsung L200... | Answered on Mar 06, 2014
Samsung L200 Digital Camera Logo
360 questions posted
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cameras
  • Samsung Cameras
Most Popular Question
recently replaced lens samsung l201 but
  • Cameras
