20 Most Recent
Nikon D300 Digital Camera with 18-200mm f/3.5-5.6G ED-IF AF-S VR DX Lens Questions & Answers
My friend dropped my nikon d3000 on the floor at
The symptoms you describe make it sound like it will not be worth the cost of a rush repair. Because these 18-55 were shipped as part of millions of Nikon cameras they are cheap and easy to come by in camera store and pawn shops.
Camera not connecting to computer
If the cable is working fine then check the port on both camera and PC. on the camera maybe there's some dirt or lint stuck on the port try to clean it. On the PC might wanna try other ports usually the one at the back is recommended.
My nikon d3000 wont turn on
You cant fix your camera youself call nikon they will advise
if your camera is new they will fix it for free and send it back to you.
Goodluck
Nikon D-300
I bought the first D-300 and I love it except for one thing. Sometimes when I take continues shoots the camera will freeze and will not execute the picture. The trick is to slightly move the focus of the lens and the camera for some reason will operate again. I have talked to several experts and they say that this is just part of the camera for what ever reason. Regardless I truly enjoyed all of my SLR and have fun with it. Going digital has been great! Good Luck
My d300 has a blueish contrast in all non flash
Here are the possible causes and the solutions for each:
Cause 1: The most common cause of the tint in the images is White Balance. It is possible that you have set the wrong White Balance. Since you are getting a blue tint, you might have set the white balance to 'Incandescent' (Tungsten) or 'Flash'. Changing the white balance to Auto. Most White Balance problems get eliminated by this. For this, press WB on the mode dial and use the command dial to change the values.
Cause 2: The unwanted casts could also be due to the in-camera processing. To check this, Select 'Set Picture Controls' from the Shooting menu. From the four options, select one that gives the minimum processing-- that is, either Neutral (which gives minimal processing) or Standard (It gives slight enhancements, but the tones will be balanced).
Cause 3: It is also possible that the White Balance of your camera has been tweaked. So if the above steps do not solve the issue, try tweaking the white balance to your liking. For this, press WB and use the sub command dial (the dial in front of the camera near the Shutter Release button). Check the result each time you change the value until you are satisfied with the result. As a guide, the ideal values of different settings are: Daylight (direct sunlight): 5200; Incandescent: 3000; Flash: 5400; Cloudy: 6000; Shade: 8000 etc...
