20 Most Recent
Panasonic Lumix DMC-FS5 Digital Camera Questions & Answers
Download software
I think you need software to manage your pictures on the computer. And you don't have the CD that came with the camera. Most camera manufactures, do allow you to download the software once you have registered the camera online. To my knowledge is that the only way to get the software legally and (almost) for free.
Which driver do I use for the DMC-FS5 camera to
Do you really need a driver?The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
Download software
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
Panasonic DMC-155 camera no longer uploads photos to PC
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
Language change in english softwere
Slide the REC/PLAYBACK switch to the right to the record position. Press the MENU/SET button to bring up the menu. Press cursor-left, use cursor-up/down to select the wrench icon, then press cursor-right. Use cursor-up/down to select the talking head icon then press cursor-right. Select the desired language and press MENU/SET.In the future, you can refer to the "Setting the Menu" section beginning on page 18 of
the manual.
