20 Most Recent
HP Pavilion TX2000Z Notebook Questions & Answers
I have power to my
- Check your power cord & adapter.
If its working then check the battery, reseat the battery & check.
If available then check with another battery
If no, then remove the battery & switch on the PC in AC mode.
Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
If still no display, connect an external monitor, check if display is comming.
If Display is coming then your LCD need to replace.
HP Pavilion...
Answered
on Feb 15, 2014
HP tx2000 - black screen.
Hi
The problem you are experiencing is related to the screen of your Hp.
All you need to do is to is to get to a computer store and get your screen replaced.
You can not fix a damaged screen.
GOOD LUCK
HP Pavilion...
Answered
on May 02, 2012
It shutdown suddenly
If Ur Laptop Shutdown While Working. Then First Check Out Your Bettery Life. If It is ok Then Make Sure Your Laptop Didn't Heat more.
If Still You Face Problem Then Contact Hp Care No : 1800 112267.
HP Pavilion...
Answered
on Aug 09, 2011
This is what happen my wife click on the Fn an on
I am not familiar with the half moon, but most laptops allow you to hold down the function key (Fn) and tap either the F5 or F6 key and switch the output of the LCD from the screen out the D-shell RGB connector to a cable connected to another monitor such as your TV screen or a stand alone. I say F5 or F6 as it is different on different machines. Ordinarily if you hold down the Fn key and re-tap the half moon key it should reverse what your wife has done. The keys act as a toggle on then off.
HP Pavilion...
Answered
on Mar 29, 2011
My hp tx2000 boot with
check bios and boot sequence first (F2 Whilst booting up)get to know these pages,dont change any values untill you are sure you know what your doing.Understand the "boot sequence".if you still have the error re-install operating system from external drive if necessaary
HP Pavilion...
Answered
on Mar 10, 2011
When i switch on my
Hello, that sounds a motherboard graphic problem, try this befor you sen the laptop to fix :
1- take the battery and the power cable from the laptop
2- press and hold for 10 seconds the power button
3- connect only the power cable without the battery and try to boot.
if this dont help you need to repair the motherboard
Thanks
please rate this answer
HP Pavilion...
Answered
on Jan 25, 2011
What can I do to fix my hp pavilion tx2000 because
You might have either a faulty LCD cable or screen inverter board.
The
LCD cable transfers data signal from the motherboard & video card
to the LCD screen. It also supplies high voltage DC power to the screen
inverter board. The screen inverter board works as a power supply for
the backlight lamp mounted inside the LCD screen. It converts low
voltage DC power to high voltage AC power needed for the backlight lamp.
HP Pavilion...
Answered
on Sep 15, 2010
BLANK SCREEN
? try removing the battery and then connect the adapter to turn on the computer
? if it is turning on then disconnect the cable and hold down the power button for 2 mins and try turning on the compute
HP Pavilion...
Answered
on Mar 13, 2010
