20 Most Recent Dell Inspiron 1525 Laptop Flamingo Pink Questions & Answers
My dell is now running the dell factory image restore if this works what can i do to keep it up and running???
use an antivirus for protection ...but ..my advice is to reinstall the operation system from a disk ..or usb ..and use a clean install ..after that install all programs you use..and an antivirus program ..like Microsoft essentials security ..or AVG free ..They do the job ..and are free..Also pay attention on the software you use..cause something is causing these issues..
8/30/2012 4:24:49 PM • Dell Inspiron... • Answered on Aug 30, 2012
Factory image restore
Press "Power" on the Inspiron 1525, and continuously press "F8" on the keyboard when the Dell logo appears on the laptop's screen.
Press the down arrow to highlight "Repair Your computer," and press "Enter" to select the highlighted onscreen option.
Click your preferred keyboard layout, and click "Next" to continue with the laptop's restoration process.
Type "administrator" in the username field, click "OK" and click "Dell Factory Tools."
Click "Dell Factory Image Restore," and click "Next." Click the checkbox next to the Hard Drive reformat confirmation, and click "Next."
Click "Finish" to reboot the OS after the restore process finishes, which can take up to 10 minutes
hope this helps
8/27/2012 9:59:51 PM • Dell Inspiron... • Answered on Aug 27, 2012
Basically i cant seem to
  • No webcam (optional Integrated 2.0 megapixel webcam available)
  • This is from Dell's website. Says it's optional. If it does exist it is in the center top of the display when opened, Looking straight at you.
    7/29/2011 9:25:02 PM • Dell Inspiron... • Answered on Jul 29, 2011
    2answers
    My Dell Inspiron 1525 will
    Try removing the battery and just powering on the laptop using the AC adapter. If it powers on normally without the battery then you need a new battery.
    6/22/2011 10:22:33 PM • Dell Inspiron... • Answered on Jun 22, 2011
    2answers
    I left my Dell Inspiron on shut down overnight
    Boot up with the vista disk that came with your laptop and do system recovery again. Ignore the file corruption message because your going to be reversing your OS back in time to when your files weren't corrupted. Back it up to a time you know it works, the dates will be listed. Afterwards things should be fine, but know that vista does this alot for alot of people. NOTE: when you go back in time you will not have any files you had inbetween the date you back it up to and today. OTHER THOUGHTS: those mac commercials from way back when weren't just Evil Apple iPropaganda. Consider updating to Windows 7, I've never had a problem with it- where as your boot loop error happened to me on a weekly basis.
    3/2/2011 4:02:34 PM • Dell Inspiron... • Answered on Mar 02, 2011
    My laptop turns on but when i enter my pc password
    First thing to try, start up in safe mode. When power on, keep tapping F8 key till text screen menu comes up. Choose Safe Mode.
    You will see bunch of text on screen then it will take a while before asking you to log in. (2-3 mins?)
    When logged in, do a system restore.
    Start button, Programs, Accessories, System Tools, System Restore..
    Choose to restore, choose a recent bold date when you know it worked, click Ok (or continue, forgot what it says there..) Let it do it's thing.
    This will reverse any recent change that may have caused the problem.
    If will not start again, then repost for more help.
    2/28/2011 12:23:26 AM • Dell Inspiron... • Answered on Feb 28, 2011
    After I push the button to stary my slot machine
    try uninstalling the Broadband2GO device by virgin mobile then reinstalling and reboot the system before trying the slot machine.
    1/16/2011 9:13:17 AM • Dell Inspiron... • Answered on Jan 16, 2011
    Where do you get this laptop in northern ireland?
    Have you tried Dell's web site? I was able to purchase one and have it shipped to me in New Zealand when mine was stolen. If you would prefer to find a dealer in Ireland, try Dell's customer service liink for a referral to their distributor there.
    11/13/2010 12:30:52 PM • Dell Inspiron... • Answered on Nov 13, 2010
    I cant put inspiron 1525 back together
    It could be that you have not insert the memory sticks in correctly this can result in not screen.
    1. check to see if you have the memory sticks seated in their slots correctly.
    2. remove the hard drive and re - insert it into the hard drive slot.
    7/31/2010 9:01:53 AM • Dell Inspiron... • Answered on Jul 31, 2010
    My Laptop won't register new devices
    This is just a software issue. There might be uncompatible software installed in your computer or malware. 1st thing try to disable your computer's start up (remove all the driver software you installed for new devices) then restart your computer.
    2. Connect 1 device then install the driver.
    ** if still not working need to perform windows system restore. You can choose the desired restore point or the last time you were able to use your computer normally.
    procedure: vista: http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
    **If still not working, you need to perform Factory recovery or set everything back to factory default. or use the recovery disk.
    Note: before doing any Troubleshooting in your make sure that you have back up for your important files or image for the programs that you have.
    3/30/2010 3:13:14 PM • Dell Inspiron... • Answered on Mar 30, 2010
    I have a problem with the dvd disk drive on a dell inspiron 1525
    Always be sure to close any open programs you do not need to run at that particular time. Also, close your internet connection. The reason for this is to allow the maximum amount of memory to be used by your media software.. Try this. It should work, ok? GOOD LUCK!! Lucky4lynn2
    2/23/2010 11:22:34 PM • Dell Inspiron... • Answered on Feb 23, 2010
    My webcam is blurry during video chats
    Make sure you are holding the Laptop as still as possible. If this does not work do not use the webcam for a few hours or a day.
    2/15/2010 12:47:18 AM • Dell Inspiron... • Answered on Feb 15, 2010
    Hi i have a dell inspirion 1525 flamingo pink, and
    start your laptop and tap on the F8 key when you start up.
    this will get you to the "Advanced startup Items" menu
    select "do not auto restart" near the bottom of the menu and press enter.
    This will allow the blue screen to stay up and you will be able to get the stop error code. You should be able to find a fix for it here:
    http://aumha.org/a/stop.htm
    1/19/2010 10:59:54 PM • Dell Inspiron... • Answered on Jan 19, 2010
    Dell inspiron 1525 laptop shutdown problem
    The Laptop is not responding to the Software request sent to the BIOS or one is not getting there.
    Best Solution is to make sure all of your Microsoft Updates are performed. Not just the Critical ones... but all that apply. You may see several hardware driver updates.
    This will help the Software and Hardware to communicate with each other...
    1/1/2010 2:07:35 PM • Dell Inspiron... • Answered on Jan 01, 2010
    I want to know how to just turn the webcam on
    If you have Windows Vista, please go to start button, type camera in the search box above the start button and you will find the camera.
    11/14/2009 2:50:04 PM • Dell Inspiron... • Answered on Nov 14, 2009
    I have tried reg cure ... all kinds of cures ..
    Apparently, your Windows failed to UPDATE properly. Microsoft distributes updates on "Update Tuesday" - second Tuesday of the month.
    Go to the update page to complete the updates:
    http://www.update.microsoft.com
    11/14/2009 3:01:26 AM • Dell Inspiron... • Answered on Nov 14, 2009
    I dropped my laptop-on the corner where the hard
    When you power up the computer press F8 key then enter in safe mode.
    Remove temp files.
    Scan your computer with antivirus.
    Then go to start menu-> run
    Type in run "chkdsk /r"
    then press "y"
    then restart computer then it fix error on disk.
    Let me know if you need further assistance.
    Thanks.
    10/29/2009 5:47:08 PM • Dell Inspiron... • Answered on Oct 29, 2009
    How do i fix snml validation error:img:equires the
    I would suggest you contact BEBO. There is nothing wrong with your dell computer itself.
    10/26/2009 9:56:45 PM • Dell Inspiron... • Answered on Oct 26, 2009
    2answers
    MY DELL INTEGRATED WEBCAM HAS BEEN WORKING
    This can happen for several reasons :
    1 - Multiple applications running in the backgroud (Antivirus / Spyware etc...)
    2 - Internet activity, slowing the processor.
    3 - Lack of space / Poor fragmented drive.
    4 - Drivers may be corrupted
    Corrective Actions
    1 - Close any 'unwanted / redundant applications when playing with videos.
    2 - Disconnect ethernet or wireless when creating videos.
    3 - Make space on the Harddrive (you will need 'double' the space of the video, as atemprary version is normally created first - A 30minute video ideally will require a minimum of 500meg to 1gig of space just to start with.
    4 - Re-install your web-cam drivers
    10/24/2009 8:20:28 AM • Dell Inspiron... • Answered on Oct 24, 2009
    Dell Inspiron 1525 Laptop Flamingo Pink  Logo
    Popular Tags
    49 questions posted
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
    View Most Popular
    Inspiron Dell
    • Inspiron Dell
    Most Popular Question
    tried reg cure all kinds cures
    • Computers & Internet
