20 Most Recent HP Pavilion dv9700t Notebook PC Questions & Answers
Change power supply
Are you refering to the AC jack? Have you tried another Cord/charger of the EXACT same power specs? Has the AC jack been damager due to pulling on the cord? HP Support may help: http://h10025.www1.hp.com/ewfrf/wc/product?product=3650971&lc=en&cc=us&dlc=en&lang=en&tmp_track_link=ot_we/prodlink/en_us/3650971/loc:0&cc=us
2/12/2013 12:59:22 AM • HP Pavilion... • Answered on Feb 12, 2013
Trying to connect my laptop to Hdtv with vga wire?
Ok, 14-pin is for really OLD VGA. Your cable will simply NOT work. Find a S-VGA cable (15-pin) and you are on your way to fame. By the way, make some room trashing that old cable.
12/5/2012 6:29:02 AM • HP Pavilion... • Answered on Dec 05, 2012
No cd rom recognising in hp dv9700
In device manager, delete something like a USB device and perform a hardware scan with the menu item and it will detect the optical drive if its running ok. Then you can upgrade the driver for motherboard or the cdrom if exists on their web site. If the issue persists, check BIOS and see whether it is disabled in any way before you try to disassemble it and tighten the cable connections or try that cdrom on other machines.
9/13/2012 12:22:58 AM • HP Pavilion... • Answered on Sep 13, 2012
No cd rom no sound
Do you get sound from audio files located on your computer's hard drive? If so then the fault lies with either the CD or the actual CD drive itself.Clean the CD using a cotton cloth and also try a few disks to be sure. You may need to update your media player to a newer version.Claim warranty support if possible.Take care!damnor01
9/12/2012 12:34:21 PM • HP Pavilion... • Answered on Sep 12, 2012
2answers
I need to replace my keyboard on HP Pavilion 9700, Notebook
well in order to get the repalcement call hp tech support i.e. 8004746836 and pay $298+taxes to get it replaced...if the NB is oow
12/22/2011 6:30:18 PM • HP Pavilion... • Answered on Dec 22, 2011
Push the on button power lights come on for 1
Try removing the battery and using the power adapter only. If this fails to work check your power adapter with a multi-meter (or volt meter). The reading on the meter should equal the output printed on the adapters label which should equal the input required by the laptops printed label. If there is a difference replace the power adapter
4/26/2011 6:44:37 AM • HP Pavilion... • Answered on Apr 26, 2011
Dv 9700 will not boot
how old.. could be the battery pack in the laptop
first pull out the battery from the back of the laptop and run it just on the power supply to the wall... does this work??
is the battery charge light on ??
does the notebook beep once during the start up process
tell me more details about the sounds and lights
do you get thru the initial f2 f12 screen
Let me know more please
3/25/2011 6:13:50 PM • HP Pavilion... • Answered on Mar 25, 2011
2answers
The screen is black and I am worging with external
LCD inverter is faulty- its 90%, And 10 % maybe some lcd connection is not good.
3/16/2011 8:27:14 PM • HP Pavilion... • Answered on Mar 16, 2011
3answers
How to replace battery
http://www.google.com/search?sourceid=chrome&ie=UTF-8&q=Pavilion+dv9700t#q=Pavilion+dv9700t+battery&hl=en&safe=off&tbs=shop:1,p_ord:p,cat:1564&source=lnt&sa=X&ei=zrBvTZXKCsP7lwfBpdlX&ved=0CCcQpwU&biw=1639&bih=771&bav=on.2,or.&fp=563c33928d93abad
First choose and buy a battery. Then remove the one in your computer (there should be a switch on the bottom of the computer that makes it pop out, careful though sometimes there is also a lock switch that doesn't let the other switch work until its unlocked) Then you replace, Perform a full charge before turning it on your first time, And your done!
Thumbs up me if this helped please! Comment with more questions.
Dave
3/3/2011 3:19:03 PM • HP Pavilion... • Answered on Mar 03, 2011
2answers
The power lights on the
lights blinking means your laptop is restarting after every 5 seconds. Your lappy might have gpu( graphics processing unit ) dry solder connection problem. I would get it looked at because it could also be a heat problem
3/1/2011 2:43:22 AM • HP Pavilion... • Answered on Mar 01, 2011
Today, my computer turned on for the first time
The problem is your motherboard is defective or the bios is corrupted.
2/3/2011 4:08:39 AM • HP Pavilion... • Answered on Feb 03, 2011
I have a DV9700 with the very dim image display
You could be right about the problem being the inverter or the CCLF lamp, it could also be as simple as a loose cable by what you are describing in your post. If it is the CCLF lamp then you would be better off purchasing a new screen as the labour cost can amount to more than a new screen itself. If its the inverter then it could just need soldering to re-float the solder around the coil.
Seeing as you don't feel comfortable making/troubleshooting the problem yourself then I recommend that you click on the link below and give BnyTech Inc a call and see what they can do for you and at what cost. Link below >>>>
http://www.bnytech.com/
They are based in the "New Yorker" building NY
Good luck.
1/5/2011 6:58:37 AM • HP Pavilion... • Answered on Jan 05, 2011
2answers
How do uninstall yoostar webcam software from the
Go to device manager...
If you are using windows XP/ Vista...
Right click My computer and choose properties -> Hardware and device manger, (Vista) Start -> Start Search -> type device manager .
Click on the USB dev ice or any camera devices available there Right click on the camera device and go to properties. In the tabs which is available you will have an option called ' Roll back driver'. If you click on that then the driver update will be uninstalled.
1/2/2011 12:24:00 PM • HP Pavilion... • Answered on Jan 02, 2011
I was given a hp pavilion laptop and i am unable
you need a internet connection if you already have one then call you internet service provider
10/17/2010 5:48:39 PM • HP Pavilion... • Answered on Oct 17, 2010
We have a hp pavillion 9700 that we cannot open
This indicates that the wire bundle running through the hinge has been compromised. Some wire has frayed apart and is making intermittent contact with itself or the lid movement is causing the wire bundle to pull on one of the video connectors.
In order to fix this problem, you will need to remove the laptop's front hinge cover & check the bundle of wires connecting the motherboard to the LCD screen. If this bundle of wires is damaged, then you will have to get it replaced.
10/16/2010 9:57:43 PM • HP Pavilion... • Answered on Oct 16, 2010
Pavilion dv9700, screen goes black
Sounds like a loose lcd cable, I'd check to make sure it is secure (back of lcd) and where it connects to the motherboard. Usually a piece of tape right where it connects solves the problem ;)
10/9/2010 11:05:00 PM • HP Pavilion... • Answered on Oct 09, 2010
Hi when i hit the power button on my hp laptop the
This usually happens if the battery is completely dead and needs recharging for awhile. Unplug the battery and try to turn it on if you want to test this immediately.
Otherwise the power adapter might be malfunctioning. These are fairly cheap on Ebay (10-20$) I have bought one of these and it works just fine. But you can also buy brand name ones at computer retail stores for exorbitant prices of 80-100$.
9/29/2010 6:17:40 PM • HP Pavilion... • Answered on Sep 29, 2010
HP Pavilion dv9700t Notebook PC Logo
109 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
dv9700 very dim image display
  • Computers & Internet
