20 Most Recent Fisher and Paykel WA37T26 Top Load All-in-One Washer / Dryer Questions & Answers
WA37T26 rinse/spin cycle
if it is set on Eco it will do a lot of spray rinse cycles to save water.
8/28/2017 7:43:08 AM • Fisher and... • Answered on Aug 28, 2017
Panel cover for pause button broken need to
this happens with these machines over time if pressed too hard, you need to call F+P and get a new decal / top panel, depending on which is damaged.
11/11/2013 11:13:29 AM • Fisher and... • Answered on Nov 11, 2013
Washer not draining
try checking the filter or drain hose you may also check the pump it sounds like the is a blockage somewhere
12/2/2011 9:06:30 PM • Fisher and... • Answered on Dec 02, 2011
0answers
Fisher and Paykel top loader, throws up TOP FULL and won't wash. Just keeps filling then emptying a little water but won't wash.
First try a power reset. Remove the power plug over night. Press and hold the power button for 1 minute. Plug back in. Or, the water level sensor needs replacing. https://www.google.com/search?q=Fisher+and+Paykel+top+loader+TOP+FULL+and+won%27t+wash ..
4/15/2024 7:36:42 PM • Fisher and... • Answered on Apr 15, 2024
My fisher paykel front loader is stuck on drum clean and when ever you press a button it just keeps beeping
Ignore most of these comments. The fix is simple, this machine does this to force you to run a drum clean. Simply hold the lock key button until it unlocks, then run a drum clean cycle.
4/10/2024 7:54:02 AM • Fisher and... • Answered on Apr 10, 2024
Fisher & Paykel Smart Drive Pride 5.5 Top Load turns off?
That sounds indicative or either a failed controller board or bad connections on it. What you can try if you wish is getting to the control board and spraying all the connecters with electrical switch cleaner. For any board edge connectors remove the connector, spray the contacts on the board edge and polish the board edge contact strips with a piece of kitchen towel. If that doesn't fix it call for service and diagnosis as control boards are expensive, so you need not only a correct diagnoses but warranty on the part and the labour. The other possibility as an afterthought, as the drain blockage caused this, is the pump working okay? These machines have self test procedures on the pump, and if the pump doesn't pass, the machine shuts down. If the drain was blocked and the pump was running for an extending time, it may be heat stressed. That would be a much cheaper repair. Further ideas in this link https://www.google.com/search?q=Fisher+%26+Paykel+Smart+Drive+Pride+5.5+Top+Load+turns+off+after+filling ..
2/7/2024 5:55:55 AM • Fisher and... • Answered on Feb 07, 2024
E6 error on dishwasher Fisher and Paykel model DW60CEW1. Do I call an electrician or a plumber to fix it?
Neither, call a domestic appliance service engineer.
8/11/2023 11:15:32 PM • Fisher and... • Answered on Aug 11, 2023
Fisher Paykel IWL12 25" Top-Load Intuitive Eco Washer. Repeated bearing failures in Fisher Paykel IWL12 -- Any ideas?
Did he replace Bearings AND Seals. The seals protect the bearings from water damage and rusting. Apply lots of Water Pump Grease even if it is a supposedly sealed bearing. Also make sure they are genuine OEM bearings and not Chinese copies. This link shows two bearings and a seal. There is good advice at the bottom of the page. Not sure if for your model, but the advice is sound. https://partsdr.com/part/429565p-bearing-kit FWIW, front load washers are the way to go, except they take up a bit more footprint. They are far more Eco than any top loader. ..
7/25/2023 6:41:31 PM • Fisher and... • Answered on Jul 25, 2023
Fisher & Paykel GW712. Fills with water but the wash cycle doesn't start - doesn't agitate.
Question edited for full maker name. This site does not do well with abbreviations. Question moved to maker category. It may be a failed control board, but a few things to try first.
Why Is My Fisher And Paykel Washing Machine Not Starting?
JustAnswer https://www.justanswer.com > Appliance Repair Jan 30, 2009 - 1.With the machine off: Press and hold the WASH TEMP DOWN button and then the POWER button until the machine gives 2 short beeps and lights up. 1 answer ยท Top answer: Unfortunately yes. The parts only come from Fisher and Paykel and the board....
Troubleshooting
Fisher & Paykel https://producthelp.fisherpaykel.com > QuickSmart Jul 6, 2017 Problem Possible Causes What to do Washer not turning on. Household power supply not working. Try plugging in anoth... Touching does not start the fill. Washer door not closed properly. Open and reclose door. Touching does not start the fill. Delay start maybe set. Refer to 'Wash cycle... View 47 more rows
6/23/2023 11:58:03 PM • Fisher and... • Answered on Jun 23, 2023
My Fisher and Paykel dryer (#ED56) won't start. Turns on, low hum
The Start/Run Capacitor has failed. The capacitor give the motor a voltage jolt to get it going.
Capacitor - 7uF
Fisher & Paykel https://www.fisherpaykel.com > laundry-spare-parts Capacitor 7uF for Dryer. 400V. Note: Does not suit some older models with an Emmerson (square) motor. Capacitor - 7uF. $ 43.83. Add to Cart. $ 43.83Each. A$43.83
Capacitor 7uF 450V Fisher Paykel Dryer ED57, AD55AU ...
eBay https://www.ebay.ca > itm > Capacitor-7uF-450V-Fish... Capacitor 7uF 450V Fisher Paykel Dryer ED57, AD55AU 93214A, ED56AUFP, AD55AU ; Type. Capacitor ; Installation. Built-In/Integrated ; Compatible Model. ED57, AD55AU ... A$12.95
Fisher & Paykel Dryer Capacitor for Motor 7UF Microfarad
Steve's Appliance Spares https://www.appliancespares.nz > products > fisher-pa... Genuine ICAR Capacitor Genuine Manufacturer used by Fisher Paykel for dryers, ActiveSmart fridge-freezers and sold by spa pool stores across NZ DUCATI. NZ$13.03 ..
5/29/2023 5:56:38 PM • Fisher and... • Answered on May 29, 2023
2answers
My clothes dryer is heating but not spinning. Fisher and paykel model DE50F56A2 - 5kg. Can hear buzzing sound but not spinning. Please assist me.
needs a new belt or the belt slipped off either way.. that is your issue
5/11/2023 7:12:37 AM • Fisher and... • Answered on May 11, 2023
Fisher and paykel washer machine model GWL 15 keep popping the fuse
A short circuit in the motor is the most likely reason. You need a service engineer to correctly diagnose.
4/10/2023 10:05:36 PM • Fisher and... • Answered on Apr 10, 2023
Fisher and paykel washing machine E702 or E701_Front loader
Try first resetting it..unplug for 5 minutes then plug back in to see if it resets to factory settings.
3/16/2023 4:19:56 PM • Fisher and... • Answered on Mar 16, 2023
2answers
Fisher and Paykel Top Loader washing machine model WA7060 suddenly won't turn on.
If you have already tried all the logical troubleshooting tips and the Fisher and Paykel Top Loader washing machine model WA7060 is still not turning on, there may be a few potential causes:
  1. Power supply issue: Check if the power outlet that the washing machine is connected to is working correctly. You can test the outlet with another appliance or device. If the outlet is not working, you may need to call an electrician to fix it.
  2. Control module or power board failure: If the power supply is not the issue, then there may be a problem with the control module or power board of the washing machine. In this case, it may need to be replaced or repaired by a qualified technician.
  3. Faulty power cord: The power cord may be damaged or faulty, causing the machine not to turn on. Check if the power cord is properly connected and if there are any signs of damage. If there are, replace the cord with a new one.
  4. Circuit breaker tripped: Check if the circuit breaker for the washing machine has tripped. If it has, reset the breaker and try turning the machine on again.
If you have already tried all these troubleshooting steps and the washing machine is still not turning on, it is best to contact a qualified technician to diagnose and fix the issue. They will have the tools and expertise to identify the root cause of the problem and recommend the best solution.
3/3/2023 5:49:12 AM • Fisher and... • Answered on Mar 03, 2023
Fisher and Paykel front loader grinding noise
There could be a few possible reasons for the grinding noise in your Fisher and Paykel front loader washing machine. Here are a few things to check:
  1. Check the drum paddles: If the drum paddles are worn or broken, they can create a grinding noise during the wash cycle. Check to see if any of the paddles are loose or damaged.
  2. Check the drum bearings: The drum bearings are responsible for supporting the drum and allowing it to spin smoothly. If they are worn or damaged, they can cause a grinding noise. To check the bearings, try spinning the drum by hand. If it makes a grinding noise or feels rough, the bearings may need to be replaced.
  3. Check the drive belt: If the drive belt is loose or worn, it can cause a grinding noise. Check the belt for any signs of wear or damage, and make sure it is properly tensioned.
  4. Check the motor: A faulty motor can sometimes cause a grinding noise. If you suspect the motor is the problem, it's best to call a professional for assistance.
If none of these solutions fix the problem, it's best to call a professional to diagnose and repair the issue.
2/26/2023 4:54:09 PM • Fisher and... • Answered on Feb 26, 2023
Fisher and Paykel WA1068G1 totally dead.
If your Fisher and Paykel WA1068G1 washing machine is completely dead, it could be caused by a few different issues. Some possible causes include:
  1. Power supply issue: Check to make sure that the washing machine is properly plugged in and that the outlet is functioning properly. Also, check the circuit breaker or fuse box to see if a circuit breaker has tripped or a fuse has blown.
  2. Control board issue: The control board of the washing machine controls all the functions of the machine. If the control board is faulty, the machine will not turn on.
  3. Faulty door lock: The door lock is an important safety feature that prevents the door from opening while the machine is running. If the door lock is faulty, the machine will not turn on.
  4. Motor problem: The motor is what powers the washing machine's drum. If the motor is not working, the machine will not turn on.
It's best to consult the manual or a professional technician to diagnose the problem and recommend the appropriate course of action. Sometimes, the problem can be solved by resetting the machine or replacing a part, but in some cases the machine may need to be replaced.
1/15/2023 7:17:14 AM • Fisher and... • Answered on Jan 15, 2023
Fisher and Paykel WA37T26 Top Load All-in-One Washer / Dryer Logo
16 questions posted
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Washing Machines
Most Popular Question
wa37t26 rinse spin cycle
  • Washing Machines
